Thread: Recall
Results 41 to 60 of 61
  1. #41 Re: Recall
    SE Level Member prostreet's Avatar
    south elgin,illinois
    what happens if you just bought your car can you just take the car to the dealer
  2. #42 Re: Recall
    Saraland Alabama
    once they open up the recall the dealer can pull the vin and use that
  3. #43 Re: Recall
    GT Level Member japslpr's Avatar
    VA Beach
    Well in all fairness, Im not convinced what they stated as the issue is really the issue. First off, motor oil leaking out the valve cover gasket is not going to just spurt out with hard braking, thats a bit of a stretch there. Unless the oil is just gushing out in which case there would be other issues. Next, motor oil even with the maximum allowed 2% fuel dilution still has a flash point approaching 300*. Good clean quality motor oil is going to have a flash point much higher, appraching 450*. Fire points are approaching 500*. Oil just does not ignite that easily and even if it does it does not burn well enough to sustain that kind of ignition with that little oil. Next, the oil would have to ignite, burn hot enough to light up the plastic tray the point out. Now, you and I know that that plastic is not going to ignite easily either as it is intended to survive a hot climate being that close to the manifolds.
    And I base all this on stagnant air flow. It doesnt take into consideration of any vehicle movement that would cause air flow of any kind. Thats just going to make the ignition and sustainability of any fire that much harder.
    Basically Im just not convinced that the valve cover gasket is the issue. I would say best case scenario it would take an extreme set of circumstances to generate that kind of fire from oil 'drops' as they stated. And they are citing what, 1 in a 1000 cases or something like that? I dont buy it.
    I used to work for GM at a pontiac dealership and when I got this letter, I was kinda upset, because the letter clearly shows they really don't know what is causing it. However from my experience working on all types of 3800's, I don't believe it is from oil at the valve cover. I have really never seen extreme leaks at the valve cover and I have worked on plenty of these cars.
    I have seen where fuel sits on top of the supercharger when the fuel lines leak though. And that would be cause for fire way more than the oil on the headers.
    Check this.... I went to the Junkyard Monday and say 4 Grandprix's. None were GTP's. 2 GT's and 2 SE's....Tell me why both the GT's engines were burt to a crisp. BOTH OF THEM AT THE SAME JUNKYARD?!! And they say the NA's have nothing to worry about.
    Jae Harris: 1999 GTP, PARTED OUT
    1997 GTP: K&N 9", Stage 3 Gen 3, ZZP Hub w/ 3.25, S/S Headers, T&D Split Ratio RR (I-1.6, E-1.7), DHP 1.0, BEAR Big Brake Kit, 17x9 Cobra R's, GMPP Strut Towers F/R, Stage 1 Custom Cam
  4. #44 Re: Recall
    Jan 1970
    Maquoketa, Iowa
    Quote Originally Posted by japslpr View Post
    Yep, I've been looking at salvage yards for wrecked grand prix's for a few years now and about 60% of the cars I have seen had engine fires. I recall seeing more N/A GP's than GTP's, though some of them were so burnt you couldn't open the hood to tell...
  5. #45 Re: Recall
    GT Level Member GreenNirvana101's Avatar
    Feb 2008
    Wisco
    Sweet - so I just got my recall done on Tuesday... with a new valve cover gasket... but guess what - oil is pretty much 'flowing' onto my exhaust manifold AGAIN.
    Back to the dealership on Monday... maybe they can get it right the second time.
    Former Camaro muscle and DSM turbo owner - now moving into the GTP Supercharged world!
    1997 GTP - STOCK.... for now
  6. #46 Re: Recall
    Feb 2008
    Wisco
    Well what the hell.... now today it isn't leaking anymore? There's just a bunch of white and burnt residue on my exhaust manifold... but its no longer leaking.
    Is it possible to have leaked and then sealed itself back up? This mind-boggling.
  7. #47 Re: Recall
    Saraland Alabama
    white residue? That doesn't sound like oil
  8. #48 Re: Recall
    GTP Level Member GTPluv's Avatar
    Enid,Ok
    Mind bottle-ing
  9. #49 Re: Recall
    TDCRacing
    Guest
    Quote Originally Posted by GreenNirvana101 View Post
    so did you wait for the second letter or did you just go up there and tell them about it and they fixed it?
  10. #50 Re: Recall
    Feb 2008
    Wisco
    I never receieved the first letter becauses I bought the car before GM had me registered into their system. Therefore, I had to call GM and a representative helped me out and got me and appt with the dealership. They checked it over and said I def need the recall done asap because it was burning a lot of oil on my exhaust manifold... it took about a week to get the parts..... and then they did the recall for me. Earlier in this thread I gave a looooong story about it.
    However, the gasket sometimes leaks and sometimes doesn't.... I'm going to take a picture today of what I mean by the "white residue" on the first exhaust manifold tube... thats where it was like leaking and bubbling while running.
    So ill ask again - is it possible for it to leak and then kind of seal itself back up again? Sounds too good to be true.... regardless, its going back to the dealer on Monday.
    Thanks.
  11. #51 Re: Recall
    TDCRacing
    Guest
    well it would be possible if you floored it and the rpm's went up to lets say 5500. because then there is more oil going to the rockers to give them the proper lubrication therefore there might be some oil seppage because of that.
  12. #52 Re: Recall
    GTX Level Member stlmo_gtp's Avatar
    St. Louis
    speaking of leaky valve cover gaskets mine are getting pretty bad, but i haven't decided either 1. i just do it myself and get it over with or 2. try to wait it out until i get my second letter. anybody have any feed back on what i should do ?
  13. #53 Re: Recall
    GTP Level Member David99GTP's Avatar
    Florida
    I had the same suspicion about this. I'm not saying oil cant ignite, but dang you'd have to be experiencing a big leak. On the other hand just a small fuel leak can result in a flash fire. A small pooling of gas could ignite and cause a big fire. Our cheap plastic/rubber fuel lines melt and theres a bunch more fuel to keep the fire going.
    I installed PRJ fuel rails and now I may just bypass the quick connects and cheap plastic like stock lines with something better. I'd feel a lot safer about it at least lol.
    1999 GTP
    2002 Chevy 2500HD lifted on 36" Swampers
    http://www.cardomain.com/ride/2619487
  14. #54 Re: Recall
    Donating Users
    phila pa
    Hi I have a question.my 2001 grandprix gtp is going to be recalled for the valve cover gasket. around the valve cover is
    dry no sign of oil leak any where on the engine. do you thing I should take it back to have it change or will the dealer not do it because it is not leaking.I use full synthetic oil any change it ever 2000 mile I know it is to often buy it take 3 month to get that many miles .thanks Ron.
  15. #55 Re: Recall
    Saraland Alabama
    doesn't matter if it leaks or not, eventually it will leak
  16. #56 Re: Recall
    TDCRacing
    Guest
    hey i dont think anyone answered my last question....
    Can i take it to the dealer now....or.....do i have to wait for the other letter to arrive? I am not experiencing any problems right now as far as leaking...would it be easier just to wait?
    Thanks guys
  17. #57 Re: Recall
    SE Level Member Myprixxx's Avatar
    Apr 2008
    Decatur, IL
    so this is all 97-03 gtps right? not just the sedans? and i also just got my car about a month or two ago so will i hve to call GM?
    i knew this guy wasn't b/sing.
    michigan people have better stuff to do, like finding jobs or avoiding robbery.
    quoted from noreasonwhyy
    GenV, Full sized I/C, HAI, 3.0 MPS, N* TB
  18. #58 Re: Recall
    Enid,Ok
    I'd wait. Half of em don't even know what they are doing, or what they are supposed to do yet.
  19. #59 Re: Recall
    Saraland Alabama
    I don't think the parts are widely distributed yet either (my local dealer still shows no recall also)
  20. #60 Re: Recall
    Feb 2008
    Wisco
    Quote Originally Posted by TDCRacing View Post
    Thanks guys
    Mine was leaking very badly and smoking on the exhaust manifold... so I got mine done ASAP at the dealership... they just do valve cover gasket, valve cover grommets, reroute spark plug wires, and put in a spark plug wire retainer.
    If its not leaking right now, I bet they would make you wait until the second letter. The exception is out there for those who are already experiencing the leak and potential fire risk
