Thread: A pillar and guages
Results 1 to 12 of 12
  1. #1 A pillar and guages
    GXP Level Member ryangtp89's Avatar
    Maine
    I am continuing my interior mods, My next mod will be the a pillar and the guages. Ill get the boost gauge of course the digital air fuel mixture guage and probably the oil pressure guage, anyways how is installing the guages and stuff, i dont know anything about electronics. Also is their a write up for this if not their should be that would be helpful to alot of people starting out and want to do this for themselves.
    SLP headers, Wizaird cai, zzp1.0pcm ,slp powerflo catback, 3.4mps, NGK TR55's, 180*, zzp stage 1 hv tb,tb spacer, tb heatshield, Triple Edge Performance High performance Tranny, flipped motor mounts, spring blockers, prj 10.4mm wires, Sloted rotors & Ceramic brake pads,Alternator Voltage Booster. zzp 1.9 rockers & 105# springs
  2. #2 Re: A pillar and guages
    Donating Users Curtis's Avatar
    Missery
    IMHO a/f gauges are just for the purdy colors!
  3. #3 Re: A pillar and guages
    Oklahoma
    They arent hard to do. Do yourself a favor though, go to Advanced Auto or any auto parts store and buy you something called Add A Circuit. One for each gauge. It will make getting power to the gauges much much easier.
    I dont know if there are any how to's, but I did have some information on tying the gauges into the existing dimming circuit.
  4. #4 Re: A pillar and guages
    GTP Level Member Toasty's Avatar
    SW Chicago Suburbs
    you really think it's neccessary to have an add-a circuit for EACH gauge?
    i'm intending to run mine off the power drop behind the glove box
  5. #5 Re: A pillar and guages
    GT Level Member Going Too Phast's Avatar
    Quote Originally Posted by Toasty View Post
    Power drop works well. I have three gauges powered by it. For a clean install ZZP has a connector that plugs into the power drop. If you have an Aeroforce, then do the add-a-circuit (and don't use it to power anything else). I had fun figuring that out. D'oh!
    .: 1998 GTP : 3.5 : PT : 1.9s : Intake : DP : Plog : 180* : 605s : UD WPP : STBs : 12" Brakes :.
  6. #6 Re: A pillar and guages
    SE Level Member 1998gpgt's Avatar
    McHenry, IL
    OQCGP :: Ontario Quebec Club Grand Prix
    Gauges
    Lighting Your Gauges
    I suggest finding something other than the A/F gauge. If you are looking to see a light-show each time you drive the car, then go for it. If not, then find a guage that can be at least somewhat usefull (Tranny Temp, volt, aeroforce, etc).
    1998 Grand Prix GT 337whp/363wtq 12.952 @ 112.02
    2000 Grand Prix GT & 2007 Grand Prix GT
    2004 GTO 13.610 @ 102.69
    1985 Cutlass 455/TH350
  7. #7 Re: A pillar and guages
    SW Chicago Suburbs
    Quote Originally Posted by Going Too Phast View Post
    i purchased the zzp mating harness, but after i did, i figured out that one can buy the parts and make your own for cheaper... i posted the required parts in my stickied thread in the tech lounge on delphi connectors....
  8. #8 Re: A pillar and guages
    Moore, Oklahoma
    The can be time consuming but there not too hard to do....
    I have a triple pillar w/ Volts, Oil Presure, Boost/Vac...
    The Volts required:
    -12v switched power
    -ground
    -12v dimmer power for lighting
    -ground for lighting
    The Oil Pressure required:
    -12v switched power
    -Wire from gauge to sender installed on the motor (Electric)
    -ground
    The Boost/Vac required:
    no other wiring due to it being mechanical (used a vacuum line hooked up to the motor)
    There you have it.
    Another thing I highly recommend you doing. If you get the Autometer gauges the stock clear blub in them makes the color a white/yellish color at night a simple and cheap fix (under $5) is go to you local parts store and get a 194R blub which will be red colored blubs. IMO they match the Grand Prix red lighting interior perfect! You only need 3 blubs and they take less than 20 seconds to replace. Some guys mess with LEDs and such, thats up to you. So far my setup has worked great for years...
    Shawn W. Larsen
  9. #9 Re: A pillar and guages
    I live here. UR LOSN's Avatar
    Rockford, IL
    if you are going for an Air/Fuel gauge......my opinion....get a wideband.
  10. #10 Re: A pillar and guages
    Oklahoma
    Yeah, I do think a Add a Circuit would be needed for each gauge. Sure, you can power them all from the power drop or one power source. And while the gauges probably dont add that much load to a circuit, even with the lights on, I would prefer not to loose all the gauges at once if the power source fails or if the fuse blows.
    Its just me and how I would do things. I have each of my gauges lighted from the same power source (as the how to shows that was linked above) but each of the gauges are powered from separate fuses.
    Is it absolutely necessary? Probably not. Is it extra work? Most definitely. Is it worth it? To me it was, but thats an individual thing. If I could have wired in brand new fused circuits to the fuse block to make it look completely stock, I would have done that. Extra work, yes, but its something I would have done if the option had been available to me.
  11. #11 Re: A pillar and guages
    Ah ha! Even better.
  12. #12 Re: A pillar and guages
    Maine
    Soo im gonna be buying the pillar and gauges tomorrow soo what will i need other then jsut the gauges ? i will be getting a boost/vaccum gauge, oil pressure gauge and a voltage meter gauge.
  1. Custom A-Pillar Gauge Pod [*]
    By TommyGloves in forum How To Write-Ups/Tech Tips
    Last Post: 01-08-2008, 07:19 AM
