Thread: same engine block?
Results 1 to 20 of 23
  1. #1 same engine block?
    Apr 2009
    Lima, Oh
    do the gt and the gtp have the same block. im finding alot of gt's for sale cheap and i need a new block for my gtp. can i use the engine out of the gt and have everything fit like it should?
    2002 Black GTP, 3.2 pulley, CAI, Pacesetter Headers, 180 thermostat, xp cam, L32 rods, zzp pcm, N* TB, FWI
  2. #2 Re: same engine block?
    Barksdale AFB, LA
    The block is the same, but the pistons have a higher compression ratio on the non supercharged engines.
    2009 Subaru Impreza WRX STI
  3. #3 Re: same engine block?
    Banned - Busted For Scamming
    Feb 2009
    you could use the gt shortblock, its gonna be higher compression, thats what i have. you can find alot of those engines in good shape because they didnt have the s/c. just swap the heads, lower intake and supercharger and other stuff related to the m90.
    Logan
  4. #4 Re: same engine block?
    And have fun with more HP
  5. #5 Re: same engine block?
    cant wait to run an l36 block again. high compression rules.
  6. #6 Re: same engine block?
    Can't wait for my L26 build
  7. #7 Re: same engine block?
  8. #8 Re: same engine block?
    Minus the rods
  9. #9 Re: same engine block?
    Barksdale AFB, LA
    Minus the rods
    04 L26s had L36 rods. Watch what you buy.
    And yes the higher compression rules. I always thought the L67 was a pig off the line and in general around town out of boost. I figured it had something to do with the intake design or something. No, it's the lower compression. My car feels like a beast down low and then boost sets in and it really takes off.
  10. #10 Re: same engine block?
    Quote Originally Posted by Sabrewings View Post
    i know what you mean. it felt better when i was running N/A just driving normally. when i get into boost though this thing flies. i cant wait to have both.
  11. #11 Re: same engine block?
    okay, ill let you think they are stronger. no knock and not spinning to 6500+ RPM = not broken motor.
  12. #12 Re: same engine block?
    Apr 2009
    Lima, Oh
    anyone bored their block .020 over? is it worth it to have it done or should i just ust 9.5:1 pistons with the supercharger?
  13. #13 Re: same engine block?
    Feb 2008
    Quote Originally Posted by JayGTP02 View Post
    I'm .020" over, but only because I had to if I wanted to reuse my old block. I had a bit of a wear spot on one of my cylinder walls. I'm just finishing the break-in, but so far it is excellent! Going .020" over increased the displacement ever so slightly.
    For the money, it's probably not worth going over. The higher compression is definitely awesome, however!
  14. #14 Re: same engine block?
    Apr 2009
    Lima, Oh
    or both?
  15. #15 Re: same engine block?
    May 2008
    McHenry IL
    good question!
  16. #16 Re: same engine block?
    GT Level Member Merlin's Avatar
    May 2008
    Broken Arrow, OK
    I have never been a big fan of boring a block anyway.
    If you can keep the stock bore, keep it.
    Engineering the impossible.
  17. #17 Re: same engine block?
    Feb 2009
    the blocks are too plentiful IMO to bore them over. I went to the yard and had no problem finding a block in good condition. Even with 100k on them, if taken normal care of the L36 blocks have slight to no wear... i was even able to re use the pistion rings!!!
    Logan
  18. #18 Re: same engine block?
    Apr 2009
    Lima, Oh
    cool thanks guys
  19. #19 Re: same engine block?
    Apr 2009
    Lima, Oh
    any suggestions on where to get a tuned pcm from? ive seen them on 3800 performance but i was wondering who else has good tunes for the gp. i was a fricken idiot and did my mods in the wrong order. aparently i have to learn the hard way.
  20. #20 Re: same engine block?
    Find someone in your area with a DHP Powertuner or a HP Tuners program that can custom tune it. Blows mail-order tunes out of the water.
  1. locations on 3800 Series engine block
    By ibduhone in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-22-2009, 12:33 PM
  2. New kid on the block
    By padlock470 in forum Introductions/Noob Questions
    Last Post: 12-23-2008, 04:05 PM
  3. New guy on the block
    By Milestone in forum Introductions/Noob Questions
    Last Post: 06-20-2008, 12:17 AM
