Thread: what order does my plug wires go?
Results 1 to 8 of 8
  1. #1 what order does my plug wires go?
    GXP Level Member ryangtp89's Avatar
    Maine
    Soo yeah i have the memory of a goldfish but o well. I' go everything put back together And i need to know what cylinder numbers are what. Starting from the back side left to right and then the front side left to right(Passengers side to drivers side) Also while i was installing everything back together i broke a little tiny wire that is purple and it goes to the coilpack connector. The wire goes to the battery i belive, if you know what I'm talking about can i just solder that back together ?
    SLP headers, Wizaird cai, zzp1.0pcm ,slp powerflo catback, 3.4mps, NGK TR55's, 180*, zzp stage 1 hv tb,tb spacer, tb heatshield, Triple Edge Performance High performance Tranny, flipped motor mounts, spring blockers, prj 10.4mm wires, Sloted rotors & Ceramic brake pads,Alternator Voltage Booster. zzp 1.9 rockers & 105# springs
  2. #2 Re: what order does my plug wires go?
    Nov 2008
    Searcy,Arkansas
    You might want to move this to the RIGHT section.
  3. #3 Re: what order does my plug wires go?
    Nov 2008
    Searcy,Arkansas
    Okay so no one will help you..I guess I will will try! 1,3,5 are in the very back and 2,4,6 in the front. Or if my memory is right!
  4. #4 Re: what order does my plug wires go?
    Donating Users Reflective Concepts's Avatar
    Feb 2008
    should be 1 , 3, 5 in the front going from the passenger side to the driver side
    back is 2 ,4, 6 left to right from passenger side to driver side
    1 and 2 are on the passenger side
    5 and 6 are on the driver side
    3 and 4 are center
    Coil pack. top to bottom: 6,3,2,5,4,1
  5. #5 Re: what order does my plug wires go?
    Nov 2008
    Searcy,Arkansas
    LOL I had it backwards..LOL
  6. #6 Re: what order does my plug wires go?
    Feb 2008
    Updated with coil pack order. It's been a while here too, but dammit I'll never forget
  7. #7 Re: what order does my plug wires go?
    Nov 2008
    Searcy,Arkansas
    Quote Originally Posted by Reflective Concepts View Post
    I did mine like rmm In JAN! LOL O well! I had the numbers right! hahahahahaha
  8. #8 Re: what order does my plug wires go?
    Barksdale AFB, LA
    ---Firewall---
    (2)(4)(6)
    (1)(3)(5)
    ---Radiator--
    2009 Subaru Impreza WRX STI
  1. MSD vs. AC Delco Plug wires?
    By FuglyGTP in forum General Tech Discussion
    Last Post: 03-16-2009, 03:41 PM
  2. Plug wires
    By 04muscle in forum General Tech Discussion
    Last Post: 03-09-2009, 01:02 AM
  3. Plug Wires
    By stlmo_gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-12-2008, 11:56 PM
  4. Plug wires
    By JCG's-GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-17-2008, 03:12 PM
