Thread: PCM core charge
Results 1 to 14 of 14
  1. #1 PCM core charge
    GTX Level Member MTXGTP's Avatar
    wamego,KS
    when you buy a pcm do they want the core from your exact type of car like i have a 99 gp gtp or can i get a pcm from another year and send it in as my core.
    Justin Young, Kansas
    1999 silver GTP DHP pcm,3" Cattless hogan DP,Front PLOG,3.4 pulley, ported TB, ported LIM, ported supercharger housing.porting done by GBP
    coming soon: LS6 springs ,1.9rr
  2. #2 Re: PCM core charge
    GXP Level Member ryangtp89's Avatar
    Maine
    Yea i want to do the same thing. I asked zzp if they would give me a discount if i sent mine and the one from my '97 in and they said no it will just count as a core. Soo im thinking yes it will work. But just write to zzp and ask them. I just took the pcm out of my 97 gtp today soo if we can ill just send that one in just in case if something goes wront i can just put back in my original pcm.
    SLP headers, Wizaird cai, zzp1.0pcm ,slp powerflo catback, 3.4mps, NGK TR55's, 180*, zzp stage 1 hv tb,tb spacer, tb heatshield, Triple Edge Performance High performance Tranny, flipped motor mounts, spring blockers, prj 10.4mm wires, Sloted rotors & Ceramic brake pads,Alternator Voltage Booster. zzp 1.9 rockers & 105# springs
  3. #3 Re: PCM core charge
    Saraland Alabama
    I bought a used one from a camaro for $25 since my pcm was toast and I needed one for driving, and they sent me 3, still have 2 floating around here
  4. #4 Re: PCM core charge
    SS-DD Level Member IndeedSS's Avatar
    St Louis MO
    I highly recommend keeping your stock PCM. Anyway you can send in a 98-03GP PCM for a core. The 97's are different as are the 04+
    04 Indy SS build #972 - Traded
    2010 Camaro SS LS3
  5. #5 Re: PCM core charge
    wamego,KS
    ok ill do that so hopefully i can try to get one anyone have one they will seperate cheap.
  6. #6 Re: PCM core charge
    Maine
    **** really, cause i have one from a '97. Well i wrote to zzp asking them soo im waiting for a reply.
  7. #7 Re: PCM core charge
    I live here. UR LOSN's Avatar
    Rockford, IL
    if you go to intense's web site...it lists 98-03, and 97. just sent in my 97.
  8. #8 Re: PCM core charge
    St Louis MO
    97's are different. Although I've not seen one, I hear they have removable modules that you keep when swappping PCM's, which help prevent the need for a CASE learn.
    2010 Camaro SS LS3
  9. #9 Re: PCM core charge
    Saraland Alabama
    that is correct
  10. #10 Re: PCM core charge
    Maine
    Ok i got my message back from zzp. He said it's fine. So im gonna send in my pcm out of my '97 and keep my original for a just in case situation.
  11. #11 Re: PCM core charge
    Saraland Alabama
    always nice to have a known good pcm when issues arise
  12. #12 Re: PCM core charge
    Maine
    thats right.
  13. #13 Re: PCM core charge
    St Louis MO
    Quote Originally Posted by ryangtp89 View Post
    Good deal, and wise move.
    2010 Camaro SS LS3
  14. #14 Re: PCM core charge
    Maine
    ftw, You nvr know what might go wrong soo it would be nice to have my original pcm.
