Thread: oil psi gauge going crazy?
Results 1 to 8 of 8
  1. #1 oil psi gauge going crazy?
    here, honestly. the link is on CGP if you want to read:
    LINK
    but, if you want to skip that..my oil pressure gauge is going crazy. isnt constant and does not work well overall. would it be the sending unit? can i fix this without buying a new gauge? electronic gauge.
    nick
  2. #2 Re: oil psi gauge going crazy?
    I live here. UR LOSN's Avatar
    Rockford, IL
    your oil pressure sending unit is messing up. this is located on the oil filter housing. you will be able to see it from the wheel well. all it does is screw into the housing on the pressure side.
    all you have to do for replacement. is to disconnect electrical connector, either drain oil if car has been run, or if cold....you are just able to unscrew it...oil will come out...if engine has been run.
    then just clean up the threads...get the oil off of it. then use teflon tape on the threads of the new sending unit...screw it in till tight. and plug in sensor and you are good to go!!!!
    gauge should work perfect. those go out constantly in the 93-97 Z28's.
  3. #3 Re: oil psi gauge going crazy?
    PA
    I would say the sending unit is the problem too (without reading the CGP thread). These are fairly common to go bad. Replace it and see from there.
    2001 GSE
  4. #4 Re: oil psi gauge going crazy?
    SE Level Member scooz14's Avatar
    West Bloomfield MI
    my buddy had a sending unit go bad, but it looked like it was a spun bearing. damn electrical gauges.
    12.591@108.00 1.95 60'
    329.9hp 400.1tq
    http://www.mccgp.com/member_details.php?mid=95
  5. #5 Re: oil psi gauge going crazy?
    its pretty static at the top end of the gauge and when i let off the gas or idle it just jerks all over the place. i was pretty sure it was the sending unit, but i wanted to see what others thought.
    found the one i need at summit, what is the thread size? 1/8-27? 3/8-18?
  6. #6 Re: oil psi gauge going crazy?
    Rockford, IL
    it should be 1/8 NPT.....
    I'd just get an oem....they care cheap.
    if the new sending unit does not cure it....pull the pan...and retorque donw the oil pick up.....
  7. #7 Re: oil psi gauge going crazy?
    nah, its the sending unit for sure. ordered one from summit last night.
  8. #8 Re: oil psi gauge going crazy?
    Rockford, IL
    let us know if it fixes it!!!
    also if you want to do a write up on it, take pics and make a HOW TO
  1. Why Does My Gas Gauge Not Work?
    By BLACKEDOUTGTP in forum General Tech Discussion
    Last Post: 2 Weeks Ago, 09:07 PM
  2. Gas gauge stuckk
    By 97grandprix4me in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-03-2012, 12:01 PM
  3. Fuel Gauge Problems
    By thermanlee in forum General Tech Discussion
    Last Post: 05-29-2008, 12:33 PM
  4. Custom A-Pillar Gauge Pod [*]
    By TommyGloves in forum How To Write-Ups/Tech Tips
    Last Post: 01-08-2008, 07:19 AM
