Thread: Brake bleeding
Results 1 to 7 of 7
  1. #1 Brake bleeding
    Jun 2018
    Lehigh Valley
    I know this isn't gp related but I am almost at my last resort. I went to bleed the brakes on my 08 Silverado because it's never been done and there's 114k miles on it. The rear brakes bleed just fine. Moving to the fronts I started the bleed procedure and then started getting air. I thought that was weird. As I continued looking for a steady stream it never came back. It looks like I bled them so much that I removed all the fluid from the front lines because as fluid was coming out the reservoir wasn't going down. I removed the master and bench bled. Got lots of air out. Put it back on, bled the rears, no problem. Moved to the front and nothing. No fluid or air. I've read the ABS module might need to be manually opened using a tech 2, but everywhere else I see on you tube and other forums nobody is having this issue. I've been bleeding brakes for 30 years and have never had this much trouble. Anyone on here ever heard of this kind of problem?
    '97 Grand Prix GT Coupe
    '05 Grand Prix GTP Sport Red Metalic SOLD
    '05 Grand Prix GTP Silver
  2. #2 Re: Brake bleeding
    Jun 2018
    Lehigh Valley
    I figured it out with some help. Apparently with this model/year I needed to pull the ABS fuses to open the module. After I did that I was able to get it to bleed.
  3. Likes mrbreezeet1 liked this post
  4. #3 Re: Brake bleeding
    St. Louis
    Well, that's a new "feature". Would have never thought of that. I'll shove that in the memory banks for sure as this is the kind of stuff that would piss me off on what should be a simple fluid flush/bleed.
  5. Likes GYSOT1, mrbreezeet1 liked this post
  6. #4 Re: Brake bleeding
    Jun 2018
    Lehigh Valley
    Ya, a simple brake bleed that took me a week to figure out and finish.
  7. #5 Re: Brake bleeding
    Jan 2021
    Ohio
    Quote Originally Posted by GYSOT1 View Post
    I take it you have to have the motor running or the key on at least to use this procedure?
    Sent from my G80 using Tapatalk
  8. #6 Re: Brake bleeding
    Jun 2018
    Lehigh Valley
    I can't remember exactly since it was a while ago. I kind of remember having the key on. The motor was not running.
  9. Likes mrbreezeet1 liked this post
  10. #7 Re: Brake bleeding
    Jan 2021
    Ohio
    Thank you.
  1. ABS Unit and brake bleeding
    By michael redmon in forum Brakes/Suspension/Chassis
    Last Post: 09-01-2016, 07:35 PM
  2. Bleeding brake system with ABS?
    By VicRDE82 in forum Brakes/Suspension/Chassis
    Last Post: 04-18-2016, 09:54 AM
  3. brake bleeding question
    By EHB in forum Introductions/Noob Questions
    Last Post: 01-02-2015, 10:14 PM
  4. Brake Bleeding Procedure
    By SJAndrew in forum Brakes/Suspension/Chassis
    Last Post: 08-12-2010, 06:20 PM
  5. 1992 Grand AM Brake Bleeding help
    By rmacinc in forum Brakes/Suspension/Chassis
    Last Post: 01-23-2009, 09:51 AM
