Thread: why did they get rid of the performance shift ?
Results 1 to 19 of 19
  1. #1 why did they get rid of the performance shift ?
    GXP Level Member ryangtp89's Avatar
    Maine
    Soo why did they end up stop making the performance shift ?? I know it doesn't make really any difference but it's still cool to have it.
    SLP headers, Wizaird cai, zzp1.0pcm ,slp powerflo catback, 3.4mps, NGK TR55's, 180*, zzp stage 1 hv tb,tb spacer, tb heatshield, Triple Edge Performance High performance Tranny, flipped motor mounts, spring blockers, prj 10.4mm wires, Sloted rotors & Ceramic brake pads,Alternator Voltage Booster. zzp 1.9 rockers & 105# springs
  2. #2 Re: why did they get rid of the performance shift ?
    I live here. UR LOSN's Avatar
    Rockford, IL
    IMO: too much of a hassle. I like the fact that when I mash my gas it is already set to go...instead of having to rememebr to hit a button. just my opinion.....
  3. #3 Re: why did they get rid of the performance shift ?
    GTP Level Member VinnieGTP's Avatar
    Las Cruces, NM
    You can still get to it. Just set up a switch on the dash to ground pin #21 on the PCM, double check that number on ClubGP, and you have the performance shift option once again.
  4. #4 Re: why did they get rid of the performance shift ?
    SS-DD Level Member IndeedSS's Avatar
    St Louis MO
    Doesn't performance shift have to be enabled in the PCM and the performance shift settings loaded in the appropriate tables? On my car which doesn't have performance shift, the normal and performance shift tables setting were identical.
    04 Indy SS build #972 - Traded
    2010 Camaro SS LS3
  5. #5 Re: why did they get rid of the performance shift ?
    Maine
    Quote Originally Posted by IndeedSS View Post
    If your's doesn't come with performance shift, it's always on. Where i have it, i have to click it to get the pcm to work, thats what it says on the description.
  6. #6 Re: why did they get rid of the performance shift ?
    Transmission Expert Trannyman95's Avatar
    Fort Wayne, IN
    GM probably needed to save $0.1378695 per car so this was the easiest novelty to chop out lol. As mentioned above if there is no switch it is basically in perf shift all the time though the light throttle shift firmness may be a bit softer than if it did have perf shift. Its not a big deal, yeah its nice to hit the button but when you pull off an exit ramp and stab the throttle then have a 5200 rpm WOT shift you get pissed pretty easy! You can add it to your car BUT as of now I think the DHP powertuner is the only tuner that will allow you to enable use of the switch as it is an option in the pcm as mentioned above that needs to be enabled. HPTuners mentioned it may be added but who knows when, I have been waiting a long long time for a few things to get added and I never get clear answers on when because the V6 cars take so long to add features to.
  7. #7 Re: why did they get rid of the performance shift ?
    SE Level Member Gearhead43's Avatar
    ATL, GA
    I believe it was due to Soccer Mom Power.....
    1989 Turbo Grand Prix Clone
    2000 Daytona Pace Car Replica #1134/2000
  8. #8 Re: why did they get rid of the performance shift ?
    Maine
    yea its a fun little button to have, and that wouldn't surprise me tht gm would do that.
  9. #9 Re: why did they get rid of the performance shift ?
    SE Level Member coltrane's Avatar
    Wichita, KS
    Like Trannyman said I think it was to save a buck, or part of it. When I got my 2001 they said the PCM had been re-calibrated so that under normal driving it would shift one way, under heavy throttle it would essentially enable a more performance-oriented drive. I got a DHP and wired the perf. shift and it was noticeably better than GM's "performance" mode. Also in 2001 they dropped the vanity lights from the doors, again I think just to save a buck across the production run.
    2000 Navy Blue GTP Coupe x2
    Current 07 Acura TL Type S
    Five time Grand Prix owner
  10. #10 Re: why did they get rid of the performance shift ?
    Maine
    Yea that sounds like something gm would do.
  11. #11 Re: why did they get rid of the performance shift ?
    St Louis MO
    Quote Originally Posted by ryangtp89 View Post
    Actually stock it just the opposite. Normal is normal but it has the performance settings in both places now. I did the same thing to my son's GTP. No one really wants to drive in normal mode anway.
    2010 Camaro SS LS3
  12. #12 Re: why did they get rid of the performance shift ?
    Maine
    ohh ok.
  13. #13 Re: why did they get rid of the performance shift ?
    Outer Space
    I just want my DIC to light up... dont really care to switch
    02 GTP 13.6 @ 100mph - SOLD
  14. #14 Re: why did they get rid of the performance shift ?
    St Louis MO
    Quote Originally Posted by Lawngoose View Post
    The PT will light your DIC up.
    2010 Camaro SS LS3
  15. #15 Re: why did they get rid of the performance shift ?
    Outer Space
    ..interesting.
    I do need a summer/winter tune anyway, so I will have to get on that.
  16. #16 Re: why did they get rid of the performance shift ?
    SE Level Member GTP SE's Avatar
    Ankeny, IA
    2001 they also dumped the fancy climate control, infavor of a manual one. I also wired the performance shift in to my 2001, and have been very pleased with it.
    2001 GTP Special Edition
    |ZZP PCM|Headers|Ported LIM and blower|3.2 / 3.4 pulley|1.9's|MSD wires|Drilled 180* T stat|3" ZZP Catback l
  17. #17 Re: why did they get rid of the performance shift ?
    Maine
    yea i was gonna ask that too, why did they loose the nice dual digital climate control. But they probably did that to save more money. I like my '99 :-)
  18. #18 Re: why did they get rid of the performance shift ?
    GTX Level Member Andrew_99GTP's Avatar
    New Salem, ND
    99 GTP FTW
    Red 2dr 99 GTP"Old" Z7 t66, A/A IC'd, Custom Heads, 65# Inj, ST2 Cam, Meziere Elec Pump, JP Double Roller(with machined crank gear), Plogs, PLX W/B, Powrtuner SOLD
    "New" 2007 Duramax ccsb with a few mods
  19. #19 Re: why did they get rid of the performance shift ?
    Maine
    Quote Originally Posted by Andrew_99GTP View Post
    99 GTP FTW
    hell ya!!
  1. Adding Performance Shift [*]
    By GeddyLee in forum How To Write-Ups/Tech Tips
    Last Post: 08-11-2014, 06:44 PM
  2. Shift Kit[*]
    By Trannyman95 in forum How To Write-Ups/Tech Tips
    Last Post: 06-03-2012, 01:40 PM
  3. Which shift kit would you recommend?
    By oldsman105 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-19-2008, 02:09 PM
  4. Bad Shift Interlock Module???
    By 1998gpgt in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-12-2008, 10:11 PM
