Thread: '04 Comp G - took a stiff one in the rear
Page 12 of 35 FirstFirst ... 2101112131422 ... LastLast
Results 221 to 240 of 691
  1. #221 Re: '04 Comp G - SHINY
    Dec 2013
    Enfield
    Whats that Chevy hiding in the background?
  2. #222 Re: '04 Comp G - SHINY
    GTP Level Member PaintChips97's Avatar
    Apr 2015
    Illinois
    '62 short bed, mild 350
    04 Comp G - a few mods, lots of OEM+ goodness, shiny stuff
  3. #223 Re: '04 Comp G - SHINY
    Dec 2013
    Enfield
    Nice!
  4. #224 Re: '04 Comp G - SHINY
    Apr 2015
    Illinois
    Took some pictures while I was out today, it's looking great! God I love this car
  5. #225 Re: '04 Comp G - SHINY
    mmmm dem rare oem wheel goodness.
  6. #226 Re: '04 Comp G - SHINY
    Apr 2015
    Illinois
    Well, it's settled. I'm putting in an order for Bilsteins sometime in the next couple of months, and after that some SSC springs for them. I'm gonna redo everything except the rear lateral arms ($500 for BMRs with adjustability I don't really need, so they can wait). LCAs, Dorman front sway, Addco rear, poly everything
  7. #227 Re: '04 Comp G - SHINY
    Push to Open GTPkirmet's Avatar
    Sep 2015
    Spokane
    Wooohoo! good choice man. I'm pretty happy with the height of my car so no more low for me
    98 GP Build?: http://www.grandprixforums.net/threa...-in-particular
    Power :Gen V, 3.6, 10.5mm, HS 1.9s, 105#, SDs, FWI, DHP Tuned, CS144
    Stuff :Gauges, 04 Leather seats, Cool stereo, Pregens, LEDs, Retros
  8. #228 Re: '04 Comp G - SHINY
    Apr 2015
    Illinois
    Mine's in 4x4 mode according to Red lol I just want it to handle as good as a GP can without getting into anything crazy
  9. #229 Re: '04 Comp G - SHINY
    Sep 2015
    Spokane
    Quote Originally Posted by PaintChips97 View Post
    Understand.. it will look great also.
  10. #230 Re: '04 Comp G - SHINY
    GTX Level Member Travisgt2's Avatar
    Jan 2013
    leavenworth ks
    Nice 04
    04 GT2: 180 t-stat, cold air intake, reptile tune, plog, hv3, gt1 cam, 90#springs, new push rods, new lifters, port polished heads, lim, uim and tb, 06 Impala brakes and steel brake lines. Cosmetic: black roof rails, under glow, Pontiac ground light, blue hud dic radio controls and cluster. To come custom hood.
  11. #231 Re: '04 Comp G - SHINY
    Apr 2015
    Illinois
    Thank you! Yours is looking good as well
  12. #232 Re: '04 Comp G - SHINY
    Apr 2015
    Illinois
    Suspension might be halted again. Went to back up last night, and... nothing, at first. I gave it a little more gas and it SLAMMED into gear, made a loud bang and started backing up. Checked fluid, doesn't smell burnt and it's at a good level. Dropping the pan and changing the fluid and filter here soon, and hopefully that'll be the end of it. Hopefully.
  13. #233 Re: '04 Comp G - SHINY
    Sep 2015
    Spokane
    oh dear... none of that sounds good... heres hoping its just a fluke man
  14. #234 Re: '04 Comp G - SHINY
    Dec 2013
    Enfield
    Do a shift kit while you are in there for sure if it has not been done, also make sure it has the bigger magnet or add a couple of smaller ones. The thin square magnet is junk.
  15. #235 Re: '04 Comp G - SHINY
    Apr 2015
    Illinois
    Quote Originally Posted by rottonj View Post
    Definitely. Also grabbing the ZZP cast aluminum pan, just in case the pan bends on its way out, plus now's as good a time as ever to upgrade, I guess
  16. #236 Re: '04 Comp G - making scary noises
    Dec 2013
    Enfield
    That pan while it looks nice is known to strip the threads on the plug. Save yourself some aggravation and a lot of money and just add a drain plug to your existing pan.
  17. #237 Re: '04 Comp G - making scary noises
    Feb 2013
    Missouri
    You can also just pic up a Dorman pan, it has a drain in it already. Stock pans won't bend unless you over tighten them. Also go with a Transog shift kit...NOT ZZP's shift kit.
  18. #238 Re: '04 Comp G - making scary noises
    Dec 2013
    Enfield
    I would look into the shift kit from Intense also, unless it has plastic washers. ZZP is plastic I think and should be avoided.
  19. #239 Re: '04 Comp G - making scary noises
    Feb 2013
    Missouri
    Agreed. Intense can firm up the shifts too much for a stock transmission (depending on the level you go with), it can cause premature wear on the hard parts. Transgo is the better choice for 99% of us.
  20. #240 Re: '04 Comp G - making scary noises
    Trans go!
    04 Comp G.
  1. The $800 GPSE resurrection.
    By EastBayGPSE in forum Members Rides
    Last Post: 03-02-2014, 04:41 AM
  2. GXP vs a Comp G
    By mrlogic1234 in forum Track Sessions and Kills
    Last Post: 06-03-2013, 10:46 PM
  3. 2003 GP se resurrection build
    By sasquatch094 in forum Members Rides
    Last Post: 10-28-2011, 07:35 PM
  4. Comp G trans in a non Comp G
    By Explicit_Spade in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-08-2011, 10:31 PM
  5. Newbie Tricked Into 97 GTP Resurrection
    By Smoker324 in forum Introductions/Noob Questions
    Last Post: 04-27-2010, 02:38 AM
