Just look for the 40w-50w bulbs, those will liquify your retinas. Lol
Dorman 927100. SOLID 33MM FRONT SWAY. lol
mine was $80...
...1mm difference.
my rear is 24mm. lol
Then you might as well do Dorman front and addco rear.. 1mm isn't going to make a difference up front
I'm sure it won't, but this came with poly bushings and everything already. $100 for the sway with poly bushings vs $80 for the Dorman that'd still need bushings, I broke even and ended up with a bigger sway. Is it gonna help? Probably not. Did I lose anything? Not really
I wasn't aware that you had already purchased some (admittedly I didn't really go through the last few responses) so I was thinking that's what you were going to buy when the time came so I was going to persuade you to save some money and just go Dorman/addco.. That being said I think you need some billet fuel rails to further fancy your bay.
Edit: and I forgot about the whole different control arm setup thing
If I hadn't found these cheap, Dorman/Addco would be what I'd do, lol. And my rail is actually bent slightly and leaks some fuel. Haven't had the guts to take a mallet to it again (did that the first time, helped at first, then heard a story about someone breaking an injector doing the same thing), so I've been considering rails. That's mucho dinero, tho
I know a guy that knows a guy that has a set
you don't have as far to go as I do... lol
Ordered the Addco bar last night. Gonna save up so I'm not broke as **** afterwards, but I'm gonna buy the BMR lateral arms, ZZP tubular LCAs (the revised ones are problem free as far as I've seen), and (finally) THE ****ING BILSTEINS. I think that ought to make for a fun ride
