Thread: Bandook's 01 Imp, top swap-ified
Page 12 of 32 FirstFirst ... 2101112131422 ... LastLast
Results 221 to 240 of 632
  1. #221 Re: Bandook's 01 Imp, top swap-ified
    Apr 2015
    Columbus, OH
    OK thanks for the confirmation. Can I use a venturi pump in my tank? Is the only difference the venturi system in the canister, but dimensions and how it fits in the tank is the same?
    I went ahead and just bought a 35.00 pump off eBay just to get it running again, until I can figure how to get a good pump in there that won't run dry or overheat.
    Top Swapped 01 Imp
  2. #222 Re: Bandook's 01 Imp, top swap-ified
    Banned
    Jan 2013
    maryland
    Quote Originally Posted by bandook View Post
    Dont know what type of gas you running or if you have fuel pump rewire... But im currently using a walboro 255lph pump on my xp ported head gen v 2.8 e85 build i just swapped bottom halfs of the pump as the walboro pump wouldnt fit our imps with swapping to a venturi style canister i would try that with your mods you have and i know you will keep modding
  3. #223 Re: Bandook's 01 Imp, top swap-ified
    Apr 2015
    Columbus, OH
    Thanks for the reply I guess, Jay...but without punctuation its difficult to understand what you are saying. You have a venturi pump? You swapped bottom half's of the pump? What does that mean? You physically separated the actual pump?
    Top Swapped 01 Imp
  4. #224 Re: Bandook's 01 Imp, top swap-ified
    missouri
    it's my understanding that the venturi pump needs the specific venturi canister to work properly. if you have the entire venturi assembly it will simply install into your tank. all the wire connections, fuel lines are the same.
    1998 to 2000 grand prix cars came with the venturi setup. another way to verify the car is in the right age range-it will have a steel gas tank. when gm switched to plastic tanks, gm stopped using the venturi pump/canister setup. got my venturi setup from a pull your part JY. it was a slam dunk easy installation.
    http://www.grandprixforums.net/threa...52#post1333352
    2000 Grand Prix 3.8 top swapped gt, headers, ported gen 3 blower, 3" catless downpipe, overkilled tune, CAI, 180, transgo shift kit, C5 front calipers, 12" f body rotors, GMPP sway bars, racetronix venturi pump w/rewire. Coming soon: strut braces
  5. #225 Re: Bandook's 01 Imp, top swap-ified
    Buffalo
    Intense sells a non Venturi pump for $100. That's where I got mine from
  6. #226 Re: Bandook's 01 Imp, top swap-ified
    Apr 2015
    Columbus, OH
    Its starting to make sense now. Thanks. I found a guy here who used to sell 255 and 340 pumps, both venturi and non. According to him all non venturi pump will have to have the canister modded. So I pm'd had m to see if he can get me a complete venturi setup with canister. I DON'T want a hacked canister. I could buy the venturi pump from zzp or somewhere, but I still need that canister. I'll post the thread I found some good info in. His company was Moar! Performance. Guys in Japan right now but last post of his he said he can still get the pumps. Hope so.
    Top Swapped 01 Imp
  7. #227 Re: Bandook's 01 Imp, top swap-ified
    Needs a HUD..
  8. #228 Re: Bandook's 01 Imp, top swap-ified
    Apr 2015
    Columbus, OH
    Nope. I can pretty accurately guess how fast I'm going without looking at the speedo.... 0 mph with a busted fuel pump. Sheesh, mods these days....
    Top Swapped 01 Imp
  9. #229 Re: Bandook's 01 Imp, top swap-ified
    i had to drop a whole canister in mine last night,,,,,thanks for jinxing me lol
    sucks when its your only car and you gotta eat it like that. but i have a spare canister now lol if e85 ever comes to town 1/2 ready for it now lol
  10. #230 Re: Bandook's 01 Imp, top swap-ified
    What you have Scott is excess trash laying around smelling like gas
  11. #231 Re: Bandook's 01 Imp, top swap-ified
    until its get a better pump, or sole to some one who needs to mod it.
  12. #232 Re: Bandook's 01 Imp, top swap-ified
    Apr 2015
    Columbus, OH
    New fuel pump in, car runs again. Even though I don't get to drive it much it kills me knowing I can't start it whenever I want. While I had the pump out I finally remembered to use my e85 tester.
    Either I messed up or Kroger sells e95-ish. Kinda hard to fill it exactly where its supposed to be. If they gave you a dropped and said put X amount of drops of water/fuel in it would be more accurate I suppose. At least I have a baseline to compare when they switch to winter stuff.
    Top Swapped 01 Imp
  13. #233 Re: Bandook's 01 Imp, top swap-ified
    Apr 2015
    Columbus, OH
    Oh, and I'm wondering sumfin'. I still have an exhaust leak at the crossover. Fixed the header tick, much quieter. Band clamp is as tight as I can get on the crossover and I can still feel air. Would it be better to hit those with an impact? Will that aluminum piece in the middle squish before the bolt breaks? Either that or grind the aluminum thinner so there is more squishability is my guess.
    Top Swapped 01 Imp
  14. #234 Re: Bandook's 01 Imp, top swap-ified
    take the band clamp off, smear some rtv around the lip of the cross over and a inch each way past the lip, then bolt the band clamp on again.
  15. #235 Re: Top Swap in progress, few questions
    Jan 2014
    AR
    Ricer as it sounds, heck I've seen collector gaskets made with just layers of foil. Many layers. Not saying foil could help you but if you added as needed, who knows? That good copper RTV works best if it can sit overnight, doesn't it Scotty? Its actually amazing stuff.
  16. #236 Re: Bandook's 01 Imp, top swap-ified
    Apr 2015
    Columbus, OH
    Scotty, You mean just under the band clamp?
    Top Swapped 01 Imp
  17. #237 Re: Bandook's 01 Imp, top swap-ified
    GXP Level Member
    Mar 2015
    Tomball
    Finally got time to read through the whole thread. Man you got this thing up and running fast. I know on later model Imp's that are flex fuel you can read the percentage of ethanol, but I am not sure how they do it wether they calculate it based on fuel flow or what, but it reads on the Tapp on the 14'. I doubt it's a sensor, so maybe it's a calculation based on some parameters it reads? As fas as the rest I'm really not sure without seeing it. The only time I have used band clamps I tightened them with a Mikita impact and snugged it down until the seam showed through the band.
    Jeff
  18. #238 Re: Bandook's 01 Imp, top swap-ified
    yup. take the clamp off slather rtv around the joint, re clamp and let it sit.
    i had to do this to the dp on the sd headers as they just kept blowing apart with band clamps. so i did the rtv trick and they never blew open again.
    ive since welded a cat in and no clamps any more on the dp.
  19. #239 Re: Bandook's 01 Imp, top swap-ified
    Apr 2015
    Columbus, OH
    OK, I'll use the rest of my tube of copper rtv tonight if I have to, and let it sit till tomorrow. After that its HF welder, and the nightmare welds that follow and will make you taste your stomach contents in the back of your throats.
    Top Swapped 01 Imp
  20. #240 Re: Bandook's 01 Imp, top swap-ified
    Apr 2015
    Columbus, OH
    Quote Originally Posted by J57ltr View Post
    Jeff
    Its probably a sensor. I looked into installing one, but they are very pricey! I'll just rely on fuel trims instead.
    Top Swapped 01 Imp
  1. Couple questions regarding build in progress
    By crbquist in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-22-2013, 11:03 AM
  2. Top swap Progress
    By 01GrandPrixTURBOGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-15-2012, 05:55 PM
  3. Top Swap progress
    Last Post: 09-14-2012, 07:04 PM
  4. Pics of my swap progress
    By NineD9GT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-04-2010, 02:44 PM
  5. Swap questions...
    By motohead in forum 3.1L V6 (LHO/LG8)
    Last Post: 06-29-2009, 11:12 AM
