You gonna cam? Good to see... are you gonna get a DOD Cam or Delete the DOD and put a big Cam in it?
Sent from my LG-E980 using Tapatalk
Gonna just get a different VLOM with different lifters/IM/TB...DoD is tuned out so I won't have to worry about it when I upgrade.
Easy peasy.
Tune this sunday.
HPT, yay.
Traded some Mustang stuff/gauges for a NX Express kit. Just need a good window switch. Was supposed to be tuned last week but HPT hates my car and had a software issue getting the Vin to work...tuner already has it fixed and I'll be getting that situated Sunday. Most of all ready for that stupid Displacement on Demand to be shut off.
Oh, and just a 75 shot. Nothing crazy. Yet.
People with nitrous kits: I was recommened a FJO window swtich, but they're discontinued. Would something like this suffice? http://www.ebay.com/itm/Nitrous-Expr...3839d1&vxp=mtr
Hell yes spray everything!!!
Is this a wet or dry kit? Im still looking for a bottle warmer solenoid and pill kit for the zex dry kit I have.
Id try nitrous outlet for whatever odds and ends you need for your kit.
2005 and hpt can be a mixed bag. But it can happen on any vehicle, contact support and they can fix it or a reflash from a dealer has worked too.
I should been subscribed to this thread a long time ago!!
I gotta look but I know there are cheaper ones out there. I'm full manual on my 100 wet shot I have manual arm and spray. So when I go wot I hit the button and cut it off at the top of 2nd gear to shift into third. Then spray again. Its a dead man switch so easy enough. I have all of 300 invested in my wet kit.
Make sure your tuner maxes out your tcc lock pressure table.
Force motor positive and negative tables--theres a last column that if conditions are right will bleed off pressure at wot...copy the prior column and move it over to the last.
Also ensuring the ve table is accurate is critical on these cars the factory map is not the most accurate.
He used to have a rocker/nitrous GXP, I'm sure he's aware. He tunes/tuned quite a bit...Area47 if you've ever heard of him.
Thanks for the heads up for NO, I'll have to check into that to see if they're any better than fleabay.
That's what we were going to do with it, but he got into contact with Bill @ HPT...we got it fixed and ready to go for this Sunday.
Window switch all the way. Nitrous outlet will hook you up.
Tuning now....
So far 28*, 12.5~ AFR...running pretty gewds
Le Updateo:
Just ordered my 2nd trans from Dave...
This one coming with some 3.69 gears and 300m's.
Should be fun for this thing.
I've always wanted them.
It should be pretty fun even off the bottle...
damn straight!! who gives a sh1t about mileage i think im maybe one of the only people that are on the same page cant wait to see how this turns out! ls4 3.69z and at least a 100 shot and PLEASE throw out the back seat passenger seat empty trunk slap on a set of real tires and take it to the strip!!!
Should be good for rolling burnout status.
That's for sure.
O damn. I was just planning to get 3.29. But damn. Let us know how it is
