Hey guys, long time lurker, but I finally had the chance to build my regal a little bit. I know it's not a grand prix but, pretty much the same thing.. just a little cooler right?
Anyways this started with just some some basic stuff like headers, intercooler, and rockers, but once I took the lower intake off and saw the coolant ports almost completely sludged from the stupid dex-cool, I had to take the heads off and it kind of snowballed from there. Heads are being done by Impastato Racing in MI, as I couldn't find a decent machine shop to do a basic head job that sounded trust worthy around me.
So far what I have is:
AGX struts
Dorman 33mm sway bar with poly link pins
all poly motor and trans mounts
yella terra 1.6 rr for less friction in the valve train
vs cam
wbs fuel rails (used)
42 lb injectors (used)
zzp stage 2 intercooler w/ ported manifold (used)
LS6 valve springs
manley Ti retainers and locks
Pushrods (I have a set that came with the yella terra's, and I have a set that of Intense Oil Restricted push rods from before I planned on putting the cam in, which ones should I use?)
Still need:
Headers (I've had 3 different sellers back out on me now)
Lifters (I hear stock are the most reliable? Mine had a lot of wear)
255lph or 320lph fuel pump? (I don't know for sure but I have a really good feeling I'll be maxing out the stock one)
N* throttlebody and LQ4 MAF (Or should I go with a different set up?)
Supercharger pulley (no clue what size I should go with though)
PCM tune (but of course waiting until I know what all my mods will be)
Would love to get (for the right price):
Meziere EWP
140 amp alternator (didn't the bonne's come stock with these?)
8 rib pulley kit
Now for pictures!!
Forgot to take a starting picture, so this is what it looked like originally, just imagine the belts ignition system and throttle body and air intake are still on there
So disgustingly cluttered, it should look a lot cleaner when I'm done. This is originally as far as I was going to tear into it, idk if you can tell from the picture though, the coolant ports in the heads were way more clogged up than I was comfortable cleaning out with them on the motor. The back head was a lot worse than the front, and when i took it off, turns out my head gasket was going anyways.
This sensor with the ziptie around it looks like a MAP sensor to me.. but for some reason I didn't think our cars had MAP sensors. Can anyone confirm this for me?
I really let this engine compartment get way too dirty in the first place. Not this time! Here's all the sludge and crap left over from when I did the lower intake gaskets and also rebuilt the supercharger, but left the case bolted to the manifold and let that nasty oil drip everywhere
Why waste time wiggling the motor and trans out the top when you can just drop the whole cradle?
