Haha it wasn't hard more time consuming than an oil change but pretty straight forward I could do it alot faster a second time
I'll probably throw it back together tonight driving the truck everyday is killing my wallet
2 extra bolts any ideas??
Tall one is for alternator, goes through the top hole, 2nd bolt is also for the alternator or alt bracket(the one with the coolant elbows)
It's quite a bit smaller than the alt bolt
That is the alternator bolt I'm holding it up to this one is pretty small like 1/4 inch
One for the egr bracket
you take a water pump bolt out? that long bolt thats missing? if one of those are out it will piss coolant out the bolt hole too.
see the two water pump bolts over the idler pedestal? maybe thats where your long bolts goes.
What size is the head on the two bolts? I'm going with 13 on the left and 15 on the right. Confirm and I should have your answer for ya.
