Thread: Topswap Bonnie build!
Page 3 of 3 FirstFirst 123
Results 41 to 49 of 49
  1. #41 Re: Topswap Bonnie build!
    GTX Level Member SnowTh1ef's Avatar
    Aug 2013
    Sandy, UT
    Speed daddys are the best for the money, I have 2 friends with them and have never bottomed out with them. Unless you weld all the joints on the pacesetters I probably wouldn't get them. Seems like a lot of people have leaking issues, but mine do not, because they've been welded at every single slip joint... lol.
    04 GTP -HAI, 1.9 rockers.
  2. #42 Re: Topswap Bonnie build!
    Aug 2013
    Sandy, UT
    Fixed my Cylinder 2 misfire issue. Changed all my coil packs and icm because I had a whole set of good knowns laying around. And its gone! Also the 4-5* of KR I was having is gone! zero. Time to put the 3.4 on today.
  3. #43 Re: Topswap Bonnie build!
    Aug 2013
    Sandy, UT
    3.4 on, and no KR! Yay! Cyl 2 misfire is back at random times under low/no load though. like idling in gear or coasting down a hill I see the CEL flash for it. But it is pretty quick now with the 3.4, now I need to get my tuner to bump the timing back up. only running 14* under WOT right now.
  4. #44 Re: Topswap Bonnie build!
    Aug 2013
    Sandy, UT
    Seems like its still having a cyl 2 misfire issue, and now has clouds of smoke out the exhaust when WOT. Might be time to retire this one.
  5. #45 Re: Topswap Bonnie build!
    Jul 2012
    Chicago
    Seems like you should diagnose before retiring it.
    -Carl
  6. #46 Re: Topswap Bonnie build!
    Aug 2013
    Sandy, UT
    Only thing left is compression test/leakdown which will be this weekend or monday. Checked all the pcv system. Its burning massive amounts of oil whenever wot.. its done.
  7. #47 Re: Topswap Bonnie build!
    Aug 2013
    Sandy, UT
    Well it has about 40 PSI of compression in cylinder 2... theres the misfire and the 2 stroke business. Time to look for another one. lol
  8. #48 Re: Topswap Bonnie build!
    Jul 2012
    Chicago
    We will rebuild it. We have the technology.
    -Carl
  9. #49 Re: Topswap Bonnie build!
    Aug 2013
    Sandy, UT
    No.. it has too many issues haha. sunroof broken/leaking. LOTS of rust. busted in fender. sell it for cheap and move on and start over. Just something good for DD status as the camaro will be my fast car now.
  1. V8 droptop Bonnie
    By Anthony Smith in forum Members Rides
    Last Post: 03-25-2014, 01:38 PM
  2. My GTP Comp G, WS6,Bonnie SLE,Monte SS
    By teamfbody in forum Members Rides
    Last Post: 10-21-2013, 04:51 PM
  3. trouble starting after topswap/build
    By MrClean in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-28-2011, 11:08 PM
  4. GXP got hit! Q: my bonnie rim?!!!
    By Specter GXP in forum Off Topic Discussion
    Last Post: 04-22-2010, 11:27 PM
  5. Bonnie GXP wheels on Prix GXP
    By TallassJonG in forum Visual/Body Modifications
    Last Post: 10-17-2009, 11:08 PM
