make sure the cashier double bags it for ya lol
She looks like she has enough white trash in her to make me happy
Its pretty hard getting in those narrow spaces with a giant thing in your hands. On another note, on a smaller version a aluminum oxide stone can do 1 entire head before its toast woop!
20160831_173624 by Corey S, on Flickr
Other one is next one day, then off to getting finer paper and going pretty
20160831_173532 by Corey S, on Flickr
Ya tell me about it so glad its inside the ring! Thats what happens when you try to move your body and keep working at the same time.
Harbor Freight has small 1/8th inch shank diamond grinding sets for cheap that work great with a Dremel or pencil air die grinder
Staring at those heads long enough I start to see a retarded whistling face
Removed this dumb lip
20160902_152021 by Corey S, on Flickr
THen bing bling! Stopped at 400grit only took 4.5hrs
20160902_161944 by Corey S, on Flickr
20160902_162014 by Corey S, on Flickr
Wow. Way better then a cordless drill and scuff pad
those look awesome
While a lot of high performance engines do polish the exhaust valves the intake valve you tend to see the they leave the machining grooves on them to increase the surface area to help vaporize the fuel sprayed on to the valve
Intake valves are not done yet, I am going to attempt what I asked you in pm a while ago, I picked up 2 of these from menards in hoping it will give me what I want.
http://www.menards.com/main/tools-ha...42658452206037
I practiced on 3 junk exhaust valves just to see with a flat edged carbide and didnt really like the out come. But I really dont know, I will practice on the 4th and see if I like it with the diamond cutoff and go from there
20160902_122504 by Corey S, on Flickr
do not induce stress risers a coarse grit in an Omni directional pattern is plenty, ideally it would be the spiral "record track" of a lathe cutting tool
Ive still got a sh1t pile of valves and at least 2 good sets of heads here. 1 complete set of valves that have had the seats cut with compound.
New denso 02, car was storing 2 codes for it.
Figured to replace the over 2 year old coppers. Well, besides the fronts looking mint, the guts of the wire on #1 ripped out and the kicker? Not a store around currently has delco in stock
Also I found out the #1 plug can rotate in itself round and round and round.
20160912_171151 by Corey S, on Flickr
20160912_171118 by Corey S, on Flickr
keep up your maintenance dude lol i like the marker line, that should have been a misfire, with the bad plug wire. any parts store wire set is fine. you dont need delco.
