Sweet hay-zoose chris-toose that is some bad rust.
Are you planning on doing anything to those messed up rockers? Or just hiding them by installing the panel? I had a few holes, so I scraped all rust, used spray foam to completely seal the hole, smoothed it out, and undercoated the whole car sealing it in. It was a decent amount of work prepping it, if you don't care much maybe spray it with something to slow down the rusting process.
Eww
Whats the point in hiding the rust? Id leave the side skirts on for that.
Panels are waiting, got sheet metal waiting, sandblaster waiting, rust bullet waiting, gmpp waiting, 2.5" exhaust waiting, new brake lines waiting, list goes on and on. I would not dare to do all this work to hide.
Leave the rust. Gives the car character.
Why did I buy a pulley puller instead of renting one? Exactly
Peeling rocker off
http://imageshack.us/a/img7/2121/4y0a.jpg
Uploaded with ImageShack.us
This was a unexpected find under the front fender
http://imageshack.us/a/img33/6136/w71b.JPG
Test fitting the panel and tacking in the beginning of the whatever panel, quarter? corner? half shaft? yup
http://imageshack.us/a/img542/1715/xv1w.jpg
My inner rocker supporter. 1/8"x3". Sure as hell aint cutting no parts out from another car thats for sure.
http://imageshack.us/a/img547/5084/8rw0.jpg
Ready to blast
http://imageshack.us/a/img853/6953/nl28.jpg
Blasted and painted with rust bullet. Now have to wait for the brother to build the front and rear corners that have gone seperate ways
http://imageshack.us/a/img542/1508/3n9w.jpg
Fking pos, this **** will NOT come off. After salt, mineral spirits, brake cleaner and everything else I could find besides sandblasting. GO ahead corey dont use gloves youll be fine.........................
http://imageshack.us/a/img593/2433/5dvi.jpg
http://imageshack.us/a/img13/5648/39cb.jpg
POR15 is the same way, get it on your hands and it takes 3 days to come off.
Subd for moree
New rear panel
http://imageshack.us/a/img689/1260/xr9g.jpg
Front fender area all cleaned up and 2 coats rust bullet
http://imageshack.us/a/img43/7932/4w2s.jpg
Lip reinforcement. About 70% of the original lip was ok, id be a fool not to make it stronger I am already down there!
http://imageshack.us/a/img819/6961/qa2y.jpg
Rocker is welded up as I type, tmw the passenger side should be finished, then off to the driver side. Then the rest of the car.
rust bullet and under coating, rust I fking DARE you
http://imageshack.us/a/img841/1227/tu0y.jpg
Get out and STAY OUT. Full lip is stupid, hey lets make a cup where **** can sit inside and rust, cup begone!
http://imageshack.us/a/img33/4073/zt7v.JPG
Walla minus blast and paint. Now onto the other side.
http://imageshack.us/a/img109/2474/jiun.jpg
http://imageshack.us/a/img823/9647/j67k.jpg
http://imageshack.us/a/img42/2492/8byu.jpg
http://imageshack.us/a/img29/926/mske.jpg
http://imageshack.us/a/img594/3729/2ly2.jpg
http://imageshack.us/a/img713/8307/z3d8.jpg
http://imageshack.us/a/img854/921/uyhb.jpg
http://imageshack.us/a/img19/8475/aean.jpg
http://imageshack.us/a/img40/7265/thm.JPG
http://imageshack.us/a/img708/8562/iwcp.jpg
:th_thumb-up:
Wanna come to fargo and do my 2000??
rocker panel is easy, its everything else that has to be custom made and pita
Nice work making them panels! Next time try some lacquer thinner to clean your hands up
Decent before picture to use
http://imageshack.us/a/img842/3756/5vwd.jpg
Rustbullet black shell. Like it never happened
http://imageshack.us/a/img18/3079/41j3.jpg
Otherside starts tmw. projected finish date with paint sat or sunday.
There will never be a before of this pic, EVER. New plate put in 1/8"
http://imageshack.us/a/img849/8853/htzy.jpg
Working on top plate, yes I had little fires
http://imageshack.us/a/img9/7210/v84m.jpg
Strut plate back on
http://imageshack.us/a/img51/6531/j3ob.jpg
Like a glove, perfect test fit
http://imageshack.us/a/img203/5214/f6ba.jpg
http://imageshack.us/a/img842/6573/rmhq.jpg
Passenger side, its getting patched, no way in HELL am I drilling that plate out again, no FKING way. Biggest PITA in the world. Patch you get fking pos.
http://imageshack.us/a/img29/1148/x0la.jpg
http://imageshack.us/a/img401/7946/3rck.jpg
