Thread: 2004 kill mode turbo build
Page 1 of 3 123 LastLast
Results 1 to 20 of 41
  1. #1 2004 kill mode turbo build
    May 2013
    illinois
    I bought the car last year it started as a junkyard car, I just cleaned it up and threw a pretty solid turbo set up together last spring and had some fun it made 522whp, this year i went a little overboard and re built the whole thing so heres a little build list and some pictures for you guys im sure the list is missing some stuff but you get the jist of it
    Motor/turbo set up
    l67 short block
    billet flex plate
    all arp bolts and head studs
    sfi balancer/ oil filter neck spacer
    l26 oil pan and pick up
    l26 front cover
    balance shaft removed and oil hole filled
    ls7 lifters
    zzp 3/8 pushrods
    .074 mls head gaskets
    ssm90 lower intake
    st5 cam
    zzp stage 3.5 heads 150 springs titianium retainers
    stattama sheet metal upper intake modifyed to use drive by wire TB
    alternator relocate bracket to clear the TB harness
    electric waterpump
    A/C delete- not just the pump everything involved with ac delete
    power steering delete
    abs delete
    modified stattama passenger side t67 turbo kit with power logs
    spearco big as **** intercooler with 3" pipes
    halman pro boost controler/ with home made 2 stage
    lots of cutting and grinding and custom brackets
    trans
    300m input shaft
    chrome moly pump shaft
    7/8ths 2.93 gears
    hardened 4th gear hub
    triple edge stage 2 valvebody
    zzp 3k stall
    home made set on kill shift kit
    large trans cooler, mounted to sweet bracket
    i have the power to the fluid presure switch hooked to a boost switch that will turn off the power and max the line pressure at 10lbs at wot to tighten the converter under heavy load
    and fresh rebuild
    fuel system
    modified fuel bucket
    dual 320lph deschwerks pumps
    two ractronix rewires
    new fuel feed out of the tank with -6 bulkhead fitting
    all stainless braid -6 lines
    still returnless with the y to return to the tank near the stock fuel filter location
    summit methanol/e85 safe filter
    zzp rails
    95lb injectors
    vacuum line ran to the top of the canister to the fuel pressure regulator to make the system raise rate with boost like an older gtp
    other crap
    moved the icm and coil packs to descrete super awesome location
    new coolant resivore infront of the radiator
    zzp lower control arms
    custom engine harness with both the fuse pannel and pcm in the glove box
    smaller brake booster with non abs master
    smaller brakes to fit 15" rims
    draglites with slicks and skinnys
    mini battery mounted to the engine cradle
    rear sway bar delete/ bumper support delete/ rear speaker delete every thing in the trunk delete/ exhaust delete (just a little glasspack off the down pipe)
    this is how the car project started
    then putting this years motor together
    i powder coated a bunch of stuff and new header rap
    repainted everything under hood
    mostly finished product i had not finished cleaning up the vac lines and some of that yet
    i have some videos and what not i can post too should be alot of fun at the track this summer im hoping for 650-700whp on e85/110 mix and she weighs in right around 3175 with a full interior and a full tank of gas on my race rims and tires
  2. #2 Re: 2004 kill mode turbo build
    Aug 2011
    'Merica
    I can't see the pics at work, but it sounds damn cool
  3. #3 Re: 2004 kill mode turbo build
    Jeez, how'd you bonk 500 pounds off the curb weight??
  4. #4 Re: 2004 kill mode turbo build
    That thing looks great so far...how about a drop to get rid of all that wheel gap? Ridin' HIGH lol
    No engine or transmission.
  5. #5 Re: 2004 kill mode turbo build
    GTX Level Member 97gtpjoe's Avatar
    Jan 2009
    Chandler, Arizona, United States
    Sweet !!!!!! Super sleeper grocery getter
    Speed Daddy Headers, Open Cone, 3.4 MPS , AL605s , 180* Stat
  6. #6 Re: 2004 kill mode turbo build
    I live here. DirtDog's Avatar
    Jun 2012
    Damn. Sounds like somebody's been busy
  7. #7 Re: 2004 kill mode turbo build
    May 2013
    illinois
    ive taken off alot of stuff lol, gutted the trunk no insulation anyware, the only thing that runs off the belt is the alternator, my plan was to make it look as stock as possible at the track full interior and all but still be pretty light so i dont kill a trans every time i race it
  8. #8 Re: 2004 kill mode turbo build
    GTX Level Member Neil98gt's Avatar
    May 2011
    Kansas city
    Love it. That is a sexy engine bay.
    Looks good on the outside too
    98 GT 2dr 116k, Sold
    07 Lexus ES350 Obsidian Black. Premium Plus package, sold
    2013 Hyundai Elantra GT
    2002 Grand Prix GT 4dr
  9. #9 Re: 2004 kill mode turbo build
    good lord. for a junk yard car it sure came out nice looking.
  10. #10 Re: 2004 kill mode turbo build
    May 2013
    illinois
    this was the first start after i had the trans rebuilt so the second first start this year lol, i killed a trans in less than 2k miles last year but i think this one will hold up a little better
  11. #11 Re: 2004 kill mode turbo build
    Donating Users akarana23's Avatar
    West Bloomfield, MI
    Can I have it? Haha nice build man, looks and sounds great!
  12. #12 Re: 2004 kill mode turbo build
    GT Level Member Nighthwk12's Avatar
    Nov 2009
    Central Jersey
    There my friends is the only time a 3800 exhaust sounds good. With a nice turbo.
    97 Bonneville SE Not so much a 97 anymore
  13. #13 Re: 2004 kill mode turbo build
    May 2013
    illinois
    thanks guys its been a fun build for me
  14. #14 Re: 2004 kill mode turbo build
  15. #15 Re: 2004 kill mode turbo build
    Texas
    Very cool build. What did you run at the dragstrip?
    85 Corvette
    01 TA
    03 Z06
  16. #16 Re: 2004 kill mode turbo build
    May 2013
    illinois
    ive only ran the car at the track once at the end of november last year, it ran a dissapointing 11.9 mainly due to the brakes not holding the car well enough to spool the turbo up, i couldnt get it on the converter and it would just start rolling, it was killing my times, ive since added a vacuum pump and now i can brake boost to whatever i want it stalls up to 4k pretty easy and ive added another 100-150whp since then so im hoping for some high to mid 10's out of it this year
  17. #17 Re: 2004 kill mode turbo build
    Feb 2009
    flintnasty MI
    A vac pump is sadly not going to help you... The absolute most vac you will get is when you free rev in neutral and snap the throttle closed, at that time you should be hammering the brakes. Unless you have a completely bad ass vac pump its not going to pull 24 inches like the motor will.
    The real trick is getting a prop valve that basically turns off the rear breaks. At that point.. Have fun when you try stopping at the end of the track.
  18. #18 Re: 2004 kill mode turbo build
    May 2013
    illinois
    the vac pump is awesome it pulls 28 inches of vacuum, i can stand on the brakes with the car at a stop and spool it up to full boost with out rolling i actually think i made a video of it last year
  19. #19 Re: 2004 kill mode turbo build
    Cambridge, Ontario Canada
    Vids please -lets go! Very nice sleeper.
    2005 E55 - stock
  20. #20 Re: 2004 kill mode turbo build
    May 2013
    illinois
    not that 15lbs would ever be useable to launch the car with but nice knowing it wont roll on the 5-7 lbs i plan to launch on this year
  1. help with my turbo build please.....
    By Bino0527 in forum Turbo
    Last Post: 04-23-2013, 11:31 AM
  2. Turbo build. Run and tell that.
    By Wotgtp in forum Turbo
    Last Post: 05-25-2012, 04:08 PM
  3. Need help with my turbo build
    By Classy Pontiac in forum Turbo
    Last Post: 11-09-2011, 08:38 PM
  4. turbo build
    By Twist in forum Turbo
    Last Post: 10-13-2011, 12:30 PM
  5. Turbo build soon to come.
    By bbptech in forum Turbo
    Last Post: 03-05-2010, 09:37 AM
