Thread: Budget Comp G. 2.5" pulley = no belt slip
Page 89 of 89 FirstFirst ... 3979878889
Results 1,761 to 1,773 of 1773
  1. #1761 Re: Budget Comp G. 2.5" pulley = no belt slip
    The Boss Iceman6669's Avatar
    Jun 2011
    I said it's not worth it but I never said 5-7 hp
    I went back and found it... LOL took me a while to figure it out.. But you are right.. You didnt say 5-7... But I was close.
    2011 F-150 Yote powered
  2. #1762 Re: Budget Comp G. 2.5" pulley = no belt slip
    A full point in compression is worth it if you can make the same power on a 3.8" as you can on a 3.4" with a low comp. motor.
  3. #1763 Re: Budget Comp G. 2.5" pulley = no belt slip
    Quote Originally Posted by blueguy View Post
    ill back this one up. my bottom swap with the stock pulley felt every bit as strong as the l67 did with the 3.4 on it.
  4. #1764 Re: Budget Comp G. 2.5" pulley = no belt slip
    Mar 2012
    NC
    My tuned top swapped L36 with stock pulley held strong with a 3.4 IC'ed car...so I guess this logic must work. LOL
  5. #1765 Re: Budget Comp G. 2.5" pulley = no belt slip
    Buffalo
    Very interesting.... I wonder where that logic puts my current motor. L26 / s3 heads/ 2.8 pulley / s3 cam vs if I did these mods in my 200k + l67
  6. #1766 Re: Budget Comp G. 2.5" pulley = no belt slip
    i think the only difference is in how much timing the l67 can take vs how the hi comp blocks that dont like it.
  7. #1767 Re: Budget Comp G. 2.5" pulley = no belt slip
    Buffalo
    So don't push the timing to max EVEN IF I don't see kr? Just keep it around 17-18 and just add boost with smaller pulleys ?
  8. #1768 Re: Budget Comp G. 2.5" pulley = no belt slip
    Jun 2011
    Negative. High comp will just knock sooner when compared to low comp. but you won't need to run as high of timing to make the same amount of power.
  9. #1769 Re: Budget Comp G. 2.5" pulley = no belt slip
    Buffalo
    I haven't had a lot of time to mess with it before I put it away. Motor only has 1500 on it. I kept the stock timing table for the most part and just skewed the cruising area of the timing table. So far I don't see any kr
  10. #1770 Re: Budget Comp G. 2.5" pulley = no belt slip
    I was saying on my car it's not worth it because I already have a low compression bottom end on both of my cars
  11. #1771 Re: Budget Comp G. 2.5" pulley = no belt slip
    It's always worth it.
    That's the point your missing.
    The point in the statement and the point of compression.
    Especially since the M90 is spun way past its efficiency range.
    You'd probably pick up power running an L36 and a 2.8"
  12. #1772 Re: Budget Comp G. 2.5" pulley = no belt slip
    Maybe but it'll never happen
  13. #1773 Re: Budget Comp G. 2.5" pulley = no belt slip
    Sold this junker 2 years ago with my turbo car and bought my g8. Best decision ever.
  1. A little burn out . lame but you should check it out.
    By drewprix86 in forum Off Topic Discussion
    Last Post: 01-14-2011, 09:39 AM
  2. Budget door comp set
    By iceman977th in forum Audio, Security & Visual Electronics
    Last Post: 12-08-2010, 07:42 PM
  3. 4 door is lame! Seriously WTF?!?!?!
    By telkel2399 in forum The Rant Forum
    Last Post: 12-07-2009, 03:58 PM
  4. How lame is this thing
    Last Post: 02-17-2009, 12:24 PM
  5. 04's are the same... lame!
    By bentendo92 in forum General Tech Discussion
    Last Post: 08-03-2008, 10:46 PM
