Even if you kept the the rockers you should be doing springs anyway.
I have comp cam 105 springs keep them? And how much should I sell them for they have 10,000 what I was told
Keep it that should be fine I'm no expert on that cam though but those springs should be fine make sure you put a new timing chain on it though you should be fine with a single roller one don't quote me on that I've never used a comp cam before
Yup keep hose springs are you could get some LS6 springs. If i was to sell them it would be around $100 or so. Run a new stock timing chain. If you go the Xp or bigger route most run a double roller which requires machining etc. Some have actually used a stock replacement chain but I guess you take a chance. You just gotta decide your goal and go from there.
Why would you have to machine it? I think if I'm going to do it I want to go with the xp so I would have to get the double I would feel safer that way so ill sell the rockers keep the springs and buy the cam and chain and new coupler for the supercharger paint to get a cleaner look and rebuild from there how much would it cost me a guess?
I believe you have to machine the crank gear down a bit so the double roller won't rub. Well it depends on if you buy used or new...Zzp for new prices. XP used to for around $225 or so. Couplers $30 or so. Nobody really rebuilds there SC they usually just get a lower mileage one anyways but most just stick with what they have.
Yeah I need to change the oil out also so I figured do that too but yeah went to the junkyard for something for my girlfriends car but I got found 04 gauges took the pins and also slp badges going to put on my car I took the ones off the cd player and the other ones just pulled back out but the slp I'm going to mount on my doors outside
Your going to put slp badges on there, what part of the car is slp? To me that's like putting GTP badges on a GT
Slp hood and airbox
You have a gtx hood I'm sorry I didn't really retread this thread before I posted that
I wouldn't overdo it with the badges. Maybe stick the SLP on the pass dashboard or something and get ros of the rest. But of course it's your car so just go with what you like.
Lol I took all the others off I just had them for ideas how they look it has nothing but the arrow on the front and the Pontiac on the back bottom bumper so I figure just the slp would look good
Found 3 pre gen for 15 each at a junkyard should I get them?
yes
id even give you 30 per wheel
Bingo look your already making money
Buy em and sell them lol anything but a 17" wheel looks bad on these cars
