Thread: My 2000 TransAm
Page 8 of 15 FirstFirst ... 678910 ... LastLast
Results 141 to 160 of 283
  1. #141 Re: My 2000 TransAm
    GTP Level Member rperry435's Avatar
    Oct 2011
    MI
    Say goodbye to any form of mpg with 4.10s
    I had a 72 Cutlass with a 455 rocket dual pumper demon turbo 350 trans and 4.10 gears... I think it was like 5mpg lol
    On a plus note it'd practically pick the front tires off the ground
    Sent from my Galaxy SIII on Tapatalk 2
    '04 CompG - 3.6MPS - 104s - FWI - TOGS - w/14"SlimFans - SLP RR' s - 180HF Stat - TEP SK - Aluminum Oil Pan - 4thGen ZZP Wires - LS7 Lifters - AeroForce - AEM WB - HPTuners - FBSS Air Ride
    ASE & State Certified Auto Electrical Tech
  2. #142 Re: My 2000 TransAm
    Oct 2012
    Nowhere NY
    there is no need for 4.10s with this conservative set up, 3.73s or 3.42s would move out pretty well while retaining some gas mileage
  3. #143 Re: My 2000 TransAm
    Banned
    Jan 2013
    Colorado
    that's so cool how the airbox is clear
  4. #144 Re: My 2000 TransAm
    GTX Level Member Juanmiguel's Avatar
    Mexico
    Quote Originally Posted by rperry435 View Post
    Yes 4:10s sound like overkill for me. The gears that I got on the picture are also OEM 3:23s. I'm going to keep the same ratio for now. Nice ride by the way.
  5. #145 Re: My 2000 TransAm
    Mexico
    Quote Originally Posted by camopaint0707 View Post
    Most are 100% clear, I got this one used and it has some kind of tint to it. I first wanted a black one, but I liked how this one looked in the end.
  6. #146 Re: My 2000 TransAm
    GTX Level Member asite57's Avatar
    Oct 2011
    Michigan
    4.10s wouldn't hurt mpgs that bad on the modern LS1 but who drives a 5.7L V8 for gas mileage anyways? That's a ridiculous statement if you want good mpgs get a 4cyl
    SOLD. 99 GTP - Open Cone, ZZP STB ,GMPP Front & Rear Sway Bar, 3" DP & Cat-Back, Built Trans, 12'' Brakes, Tune
    http://www.grandprixforums.net/gtp-t...ack-67489.html
    04 SRT4 - Bone Stock....For Now
  7. #147 Re: My 2000 TransAm
    Oct 2011
    MI
    Complaint is more towards top end speed then anything. F mpg lol
    Engine shot.
    I traded this car for a 98 LS1 Trans Am when I was 19.
    my bad didn't mean to jack the thread
  8. #148 Re: My 2000 TransAm
    Oct 2012
    Nowhere NY
    Quote Originally Posted by Juanmiguel View Post
    yes good choice, plus if you like street racing 4.10s are just going to disappoint you, not only will you run out of rpm up top but with the tires you have it would have no chance of hooking up.
  9. #149 Re: My 2000 TransAm
    3.73's are nice middle of the road even a 3.55 i think it was, in that neighborhood were also a good middle of the road.
    with a lower gear your pull harder/faster off the line but dont get the same top speed as the stock gear ratio.
  10. #150 Re: My 2000 TransAm
    Oct 2011
    Michigan
    He's got an aftermarket cam people he can do a taller ratio because he shifts higher
  11. #151 Re: My 2000 TransAm
    i know hes got a better trans and all being newer, but my brother chevelle was good for 45 mph on the highway, it would scream its ass off. lots of fun around town, but not for a long trip.
    my firebird had 3.73 gears, its launched damn good, and i got up to 150 mph, and held it there at 1/4 throttle, had lots of pedal left but never went for any more.
    my brothers car would max out at 106 in the 1/4 mile and that was about as fast as it was gonna get up to. but it got there pretty fast.
  12. #152 Re: My 2000 TransAm
    Mexico
    My sh1t is here:
    I don't know much about gears but it looks ok to me. Now the thing is that I was out driving today for about an hour or so and the rear end was screaming like crazy as usual. I have aftermarket amp and speakers and I can still hear it with the volume up. But it suddenly stopped making the noise haha. You could still hear it but it was no where near the way it used to be. I stopped for a while to pick up the box with the gears and the noise came back again.
    I thought that if the gears were shot it would not stop making the noise no matter what, am I right? Maybe it just needs an oil change and positive gear additive? I guess we will know when we drop the cover?
    Sent from my GT-S5830 using Tapatalk 2
  13. #153 Re: My 2000 TransAm
    It's Slow LS1GTP's Avatar
    Sep 2012
    Clarkston, MI
    Maybe the oil heated up enough to quiet down the noise? Not sure man. For what it costs for oil, just change it and see what happens.
  14. #154 Re: My 2000 TransAm
    Oct 2012
    Nowhere NY
    Quote Originally Posted by asite57 View Post
    Uh yeah because the "aftermarket" GMPP LS6 cam will make up for all that.............
  15. #155 Re: My 2000 TransAm
    Ohio
    Quote Originally Posted by lsxftw View Post
    Teh lolz
  16. #156 Re: My 2000 TransAm
    I live here. TLSheff's Avatar
    Quote Originally Posted by LS1GTP View Post
    ^ This. I'd get enough cheap fluid to change it out and see what happens. If it still makes noise after you gotta replace some parts. I've never heard a rear end stop making noise and not be completely broken. A friends rear end in his truck was howling like that and when it stopped making noise he said he had enough time to realize it stopped making noise, say hmmmmm, then boom, lock-up/shatter, done.
  17. #157 Re: My 2000 TransAm
    i lost the rear end in my old dodge truck, its howled like a banshee till the gears chunk ed up and locked the rear up, took 2 weeks to kill it. i was off road got hung up on some rocks and the gear oil leaked out the pinion seal. left me with no lube, and it died fast. i did refill it on the way home, but it was to late.
    so maybe your low on gear oil. end seals leak and such.
  18. #158 Re: My 2000 TransAm
    Sep 2012
    Clarkston, MI
    My pinion seal leaked a little when I got my car, like scott said, might be a good idea to check that out. It's where the driveshaft connects to the rear end, just check to see if its all oily there. Not hard to change it. I've done it on 2 different cars now Lol.
  19. #159 Re: My 2000 TransAm
    once they howl, its over from my own past experiences.
    i bet you need new bearings too. as im sure thats what is howling in the beginning.
  20. #160 Re: My 2000 TransAm
    Sep 2012
    Clarkston, MI
    Yea the bearings are usually what let go first. Get one of these, it helps hold those bearing main caps in place:
  1. 2000 GTP info center in a 2000 GT?
    By ZachBW55 in forum Visual/Body Modifications
    Last Post: 06-24-2011, 01:24 PM
  2. comp g vs transam
    By BoostedComp in forum Track Sessions and Kills
    Last Post: 07-31-2009, 11:39 AM
  3. beat a 97 transam
    By redgtp08 in forum Track Sessions and Kills
    Last Post: 04-25-2008, 03:10 PM
