Thread: BLACKxFLAGx Raising It UP! plus suspension woes....
Page 9 of 9 FirstFirst ... 789
Results 161 to 171 of 171
  1. #161 Re: BLACKxFLAGx Getting Lower *****es
    GTX Level Member blackflag's Avatar
    Virginia
    terrible pic but, HIDS!
  2. #162 Re: BLACKxFLAGx Getting Lower *****es
    So bleuuuu
    04 Comp G.
  3. #163 Re: BLACKxFLAGx Getting Lower *****es
    Virginia
    It's more "silver" in real life
  4. #164 Re: BLACKxFLAGx Getting Lower *****es
    Virginia
    So i have a rattling noise in the suspension on the right side (started off every once in awhile. Slowly got worse. Now it sounds like somethings about to break off). Ive stopped driving it until i get it taken care of. I know i have to replace a wheel hub as my abs is retarded at 17mph and codes are thrown for it. Could that be the noise? maybe it completely separated inside the housing? Or, can it be the bushings? The bushings look terrible. what is most likely the culprit? Heres pics
  5. #165 Re: BLACKxFLAGx Getting Lower *****es
    Virginia
    oops last pic shouldnt even be there. I mean, i dont even know what that thing is....
  6. #166 Re: BLACKxFLAGx Getting Lower *****es
    HAHA nice last pic looks like all cheap stuff to fix get reman cv shafts from oreillys ive always used remans never any problems like 50 bucks max after core. looks like the grease is flying all over from the inside boot. Replace that wheel bearing with a Timken wheel bearing those are the best kind to get for these cars and the abs sensor is in the hub. That is likely what is causing the most noise they get pretty nasty when they do go bad and make a ton of noise so yes that's likely the issue. Also them outer tie rods are cheap too and will make a world of difference in feel on the steering wheel. if you do one outer id recommend doing both sides and getting it aligned too. That's not too much work to do all at once then drive to a place to get aligned if you do the labor id say you should be able to do it for 200sih including wheel bearing tierods and alignment.
  7. #167 Re: BLACKxFLAGx Getting Lower *****es
    Virginia
    What about the bushings in post 3?
  8. #168 Re: BLACKxFLAGx Getting Lower *****es
    Virginia
    replaceable or do i need a new lca?
  9. #169 Re: BLACKxFLAGx Raising It UP! plus suspension woes....
    Jan 2009
    Tallahassee, FL
    The bushings look like that new, they're supposed to be split. How many miles are on them though?
    05 Saab 9-2X Linear (Saabaru)
    77 Morris Garage B
  10. #170 Re: BLACKxFLAGx Raising It UP! plus suspension woes....
    Virginia
    im guessing the original 104k
  11. #171 Re: BLACKxFLAGx Raising It UP! plus suspension woes....
    Jan 2009
    Tallahassee, FL
    Go ahead and replace them
    77 Morris Garage B
  1. Galaxy Motors - Victoria
    By WagZ in forum The Rant Forum
    Last Post: 07-30-2009, 12:07 AM
