Thread: How to remove brake booster?
Results 1 to 8 of 8
Runicdionysus How to remove brake booster? 10-08-2015, 05:02 PM
02NavyBlue Re: How to remove brake... 10-08-2015, 05:54 PM
mkyota1 Re: How to remove brake... 10-08-2015, 09:32 PM
dsmuts Re: How to remove brake... 10-09-2015, 02:52 AM
Scottydoggs Re: How to remove brake... 10-09-2015, 08:16 AM
Runicdionysus Re: How to remove brake... 10-09-2015, 08:57 AM
Scottydoggs Re: How to remove brake... 10-09-2015, 08:59 AM
Swiggles Re: How to remove brake... 10-14-2015, 08:43 PM
  1. #1 How to remove brake booster?
    May 2014
    New Mexico
    2002 GP GT. Trying to remove my brake booster so I can install the smaller ZZP one for my 3" turbo downpipe. I've unbolted the Master Cylinder, and removed the retaining clip, but the rod won't separate from the brake pedal. Am I missing something?
  2. #2 Re: How to remove brake booster?
    Dec 2012
    Where 4T65E's were born
    It should slide off with the plastic switch, wiggle the pedal at the same time.
    Sold.
  3. #3 Re: How to remove brake booster?
    GT Level Member mkyota1's Avatar
    Daytona, florida
    To remove the booster from the fire wall you need to twist the whole booster. I just stuck a pry bar against the two studs that held the master on and twist. I am pretty sure you twist counter clockwise when looking at it. The rod should slide off of the pedal assembly before trying to remove the booster.
    R.I.P.-----99 black GTX 12.9@107
    97 gp gt turbo--- Hx35, xp cam, 130#, double roller, hv3, l67 block, 42.5#, crap tune by me+ Dhp, devils own injection
    300m, 7/8" 2.93 11.78@118
  4. #4 Re: How to remove brake booster?
    My booster came loose from the firewall once while driving. It was sketchy
  5. #5 Re: How to remove brake booster?
    dont forget to to unhook the rod from the brake pedal.
  6. #6 Re: How to remove brake booster?
    May 2014
    New Mexico
    Quote Originally Posted by ScottyDoggs View Post
    That's the part I'm stuck on. I've removed the retaining clip but it won't come loose.
  7. #7 Re: How to remove brake booster?
    if the master is off the booster the rod should push in real easy. then un hook or be clear it of the brake pedal. ive taken a few out, none in a w body, i can only guess they are all similar.
  8. #8 Re: How to remove brake booster?
    Quincy, Mass
    Try using some pliers on the rod and the knob end of the pedal, you should be able,to pop it loose.
    I used a small pry bar, with the tip under the left bolt and the bar on top of the other bolt just push down and it should twist and come off.
    Sent from my iPad using Tapatalk
    No more GP 04 Impala SS Indy:
  1. Brake booster
    By 94grandprix in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-23-2021, 06:29 PM
  2. Brake Booster
    By grandamle91 in forum Brakes/Suspension/Chassis
    Last Post: 02-09-2014, 12:15 PM
  3. Bad brake booster?
    By Pure2sin in forum General Tech Discussion
    Last Post: 01-27-2012, 11:58 PM
  4. Brake booster line
    By RedGrandprixgt53 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-26-2011, 10:57 PM
  5. 2001 GTP Brake Booster
    By Greg66 in forum Introductions/Noob Questions
    Last Post: 10-28-2009, 08:37 AM
