Thread: Crank shaft sensor
Results 1 to 3 of 3
  1. #1 Crank shaft sensor
    Aug 2015
    ohio
    What's best way to check crankshaft sensor? Can you use a multimeter 99 Grand Prix
  2. #2 Re: Crank shaft sensor
    The best thing to do is you question it is check the wiring and then replace the sensor based on it often testing fine while being bad.
  3. #3 Re: Crank shaft sensor
    GTP Level Member buickman104's Avatar
    NYC
    Or check for for unwarranted P0300 random misfire codes or in pending codes you might have one waiting for crank sensor issues. My engine always ran a bit rough. After getting the codes and changing everything else in the ignition I changed the sensor and OMG the engine feels rejuvenated.
    2000 Bronze Metallic GTP
    Power :Gen V, 3.6 pulley, 3 inch down pipe, Power log, FWI,and DHP Power Tuner,
    Handling: Vogtland Springs, GMPP sway bars, STBS, 18" Konig backbone, CTS-V Front brakes and GXP rear brakes
  1. Crank position sensor
    By 94grandprix in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-08-2014, 08:54 PM
  2. 3 wire crank sensor vs 2 wire with 24x crank trigger
    By greenmachinegtp in forum PCM Tuning
    Last Post: 03-12-2012, 05:45 PM
  3. Crank sensor and DIC issues
    By lucyboop in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-12-2011, 06:28 AM
  4. camshaft sensor or crank sensor?
    By Viper in forum 3.1L V6 (LHO/LG8)
    Last Post: 09-06-2010, 04:43 PM
  5. 3.1 crank sensor wire
    By 68galaxie500 in forum 3.1L V6 (LHO/LG8)
    Last Post: 02-22-2010, 09:18 PM
