Thread: Think my engine jumped time
Results 1 to 3 of 3
  1. #1 Think my engine jumped time
    Aug 2015
    ohio
    I know everyone say chain doesn't go bad in the 3.8. It has 208,000 miles and cranks won't starts but backfires when turning over. Got spark , furl pressure and compression. If crank sensor bad do you still get spark? How can I check it with multimeter? Is there any timing marks to line up to check if timing jumped it's a 99 3.8 htp
    Yhanks
  2. #2 Re: Think my engine jumped time
    Was this an out of the blue thing or did you do something before hand and no this is going on?
    Otherwise check plug wire routing, see it runs on brake cleaner or starting fluid.
    A bad/dead crank sensor normally allows no spark.
  3. #3 Re: Think my engine jumped time
    hangover park IL
    youll wnat to use a wooden dowl to find TDC on cyl1 (through spark plug hole) then you will pull the cam position sensor off and make sure the magnet is near the center of the sensor opening.
    make damn sure you have the ignition cables hooked up correctly....sounds like you may have misrouted em
    2,4,6 (rear bank)
    1,3,5 (front bank)
    3/6
    2/5
    1/4
    firing order is 3,4,5,6,1,2 (or 1,2,3,4,5,6)
    ~James~ Psychotic Gearhead
  1. Hello just jumped on board.
    By Madcow169 in forum Introductions/Noob Questions
    Last Post: 04-02-2014, 11:31 AM
  2. New engine time soon
    By legend in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-03-2012, 07:34 AM
  3. Battery Died, jumped car, now DIC issues
    By jhub1984 in forum General Tech Discussion
    Last Post: 01-20-2012, 11:18 AM
  4. Well, I jumped in with both feets...
    By BlownBigBlock in forum Tires & Wheels
    Last Post: 06-13-2009, 08:07 AM
  5. Engine and Trans pull... SAME TIME?
    By nathangartz in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-14-2009, 09:40 PM
