While changing my plugs I accidentally leaned on this part, and broke off one the vac line connections. I just need a name for this piece cause I have no idea what it's called.
awesome, thanks guys
bet some crazy glue would get you by, but it still needs to be replaced. id never trust it.
buy a foot of new vac line too, cut the old rubber end off the hard line to the fire wall, then cut the old line off the bbv there. if you dont cut the old line off you can break the nipple off. nice sharp razor works great.
the brake booster line should come right off, dont try to cut that one.
On a side note, I noticed that the line from the manifold to the Wastegate I believe, is capped off. Any thoughts on this?
Will get one tomorrow, but for reference, in the picture above, it's the bottom line that runs to the black canister at the bottom of the picture
