Thread: can you hear kr?
Results 1 to 18 of 18
  1. #1 can you hear kr?
    Jan 2015
    illinois
    i have a 99 gtp want to put on a 3.5 pulley but i was worried about kr . can you hear kr like on an 78 350 chevy w/ the timing advanced too much. did this many times and never chipped a piston. if i get a ubend delete and 3'' downpipe 93 octane can i run the 3.5 pulley safely? also if i did what kind of 0-60 and 1/4 time should i expect
  2. #2 Re: can you hear kr?
    GXP Level Member
    Mar 2015
    Tomball
    By the time you hear it it's too late. 78 Chevy will knock like a coffee can full of pennies and still keep going.
    Jeff
  3. #3 Re: can you hear kr?
  4. #4 Re: can you hear kr?
    boy oh boy, i heard it time. then i did a engine swap lol
  5. #5 Re: can you hear kr?
    Apr 2015
    Columbus, OH
    Of course you can hear the Knock of piston fragments as they make a Reduction of themselves. Ha? Sounded funnier in my head....most things should probably stay there
    Top Swapped 01 Imp
  6. #6 Re: can you hear kr?
    it dont sound funny in real life lol it went pppppppppppppffffffffffffffffffffffffttttttttttttt ttttttt. i knew instantly i broke it.
  7. #7 Re: can you hear kr?
    Who is this guy? SubwayGuy's Avatar
    Apr 2015
    Quote Originally Posted by ScottyDoggs View Post
    Sounds normal to me...
  8. #8 Re: can you hear kr?
  9. #9 Re: can you hear kr?
    You can't hear it. Having had 15 degrees of KR.. I can tell you you can't hear KR.
    Plus in the technical sense.. KR is the timing reduction not the actual knock itself..but we know what you are getting at.
  10. #10 Re: can you hear kr?
    Apr 2015
    Columbus, OH
    Curious what makes pre detonation so mute in these cars? My Sienna I can hear it clear as day when I have 87 in, almost every time I hit the throttle. But, yeah, can't hear a thing in the Imp.
    Top Swapped 01 Imp
  11. #11 Re: can you hear kr?
    Sep 2014
    Worcester, MA
    If you know what to listen for, you can hear knock. That's how we used to tune timing curves before computers came into the picture. And since I know what I'm listening for, I can hear knock on just about every modern engine too.
    And bandook, if you can hear it then you should be using a higher octane fuel. Just because your engine hasn't blown up yet doesn't mean that you aren't contributing to the long-term damage of your car (i.e. blown head gasket etc.).
    You can't hear knock "retard" because that is a computer function to adjust the timing, after the knock sensor hears knock.
  12. #12 Re: can you hear kr?
    Apr 2015
    Columbus, OH
    Quote Originally Posted by bobc455 View Post
    It has only began pinging because of the heat we've had. I go back and forth 87-89 because its a work van. Besides, how many Toyota engines do you hear about that failed because of pre-d? I only ran 87 on my last sienna and its around 250k and still only had minor maintenance done (neighbor owns it now).
    My guess is Toyota used something stronger than a marshmallow for pistons, unlike GM?
    Top Swapped 01 Imp
  13. #13 Re: can you hear kr?
    Kemmerer, Wyoming
    I heard some knock retard the other day, turned out the jehovah witnesses were at the front door.
  14. #14 Re: can you hear kr?
    one good thing about living in a secure apt building. aka the doors are locked a the lobby. i aint seen one of them assholes in years now, and im happy about.
    when some dick does come knocking on my door to sell crap, im like who the f let you in the building, get out now!
  15. #15 Re: can you hear kr?
    GTP Level Member
    Aug 2012
    st louis park, MN
    Sometimes when I get into the throttle I get a rhythmic tinging, rattling that I've been curious about. I can only hear it if I'm driving by a fence or building that can reflect the noise from my car into my windows. I thought it may be the catalytic converter heat shield but it seems too rhythmic for that. Any thoughts? It's a N/A 3800 series III
    2008 Grand Prix Base: Engine cover delete , flipped dogbone bushings, Transgo shift kit, Hayden 403 trans cooler,
    Quote Originally Posted by Yarbeau View Post
    we are all anal about our vehicles. Otherwise we would not be on an extinct platforms forum debating 3000 dollars cars!
  16. #16 Re: can you hear kr?
  17. #17 Re: can you hear kr?
    exhaust leak if only next to the divider on the highway.
    aka jersey barrier......now you know where they were first made and installed. add that to the light bulb lol
  18. #18 Re: can you hear kr?
    ive heard them little 4 banger toyota engines pinging away when under load. but this was back in the late 80's early 90's.
  1. Noises I Hear
    By chrisgotcrisco in forum General Grand Prix Discussion
    Last Post: 05-23-2015, 03:14 PM
  2. Anyone ever hear of this guy?
    By BlackGT97 in forum Off Topic Discussion
    Last Post: 03-21-2013, 06:31 PM
  3. new hear
    By 5smitz in forum Introductions/Noob Questions
    Last Post: 03-29-2010, 07:54 PM
  4. Would like to hear from everyone???
    By lookinaround in forum Tires & Wheels
    Last Post: 05-01-2009, 09:46 AM
  5. Ever hear the Expression
    By J_Ferguson in forum Off Topic Discussion
    Last Post: 01-01-2008, 02:31 AM
