Thread: pos 05 gxp
Results 1 to 17 of 17
05scottgxp pos 05 gxp 07-28-2015, 04:21 AM
91parkave Re: pos 05 gxp 07-28-2015, 06:19 AM
Mirraco Re: pos 05 gxp 07-28-2015, 07:15 AM
J57ltr Re: pos 05 gxp 07-28-2015, 07:23 AM
stocker Re: pos 05 gxp 07-28-2015, 08:45 AM
Scottydoggs Re: pos 05 gxp 07-28-2015, 09:07 AM
Mirraco Re: pos 05 gxp 07-28-2015, 09:55 AM
REDCRAPGP Re: pos 05 gxp 07-28-2015, 10:05 AM
chrsmi1 Re: pos 05 gxp 07-28-2015, 11:56 AM
blueguy Re: pos 05 gxp 07-28-2015, 11:51 AM
Reptile Re: pos 05 gxp 07-28-2015, 05:34 PM
koRnhead Re: pos 05 gxp 07-28-2015, 03:32 PM
Travisgt2 Re: pos 05 gxp 07-28-2015, 06:04 PM
EHB Re: pos 05 gxp 07-28-2015, 06:53 PM
SubwayGuy Re: pos 05 gxp 07-28-2015, 10:31 PM
05scottgxp Re: pos 05 gxp 07-29-2015, 02:30 AM
16MustangVet Re: pos 05 gxp 07-29-2015, 03:24 AM
  1. #1 pos 05 gxp
    Jul 2015
    gridley il
    just got a 05 and man all the problems running into with this thing . about ready to set on fire and say good bye .
    1st power streering line blows come to find out the rigged it when the put the new rack and pinion in the car , so 300 dollar fix then found that one of the spindles is cracked where the tierod mounts
    so have to order one of them now too . then might as well do all new tie rod ends so know all is good ....
    2nd everyone said oh you can put 235/50/18 all way around ya not back tire rub on theshocks
    3rd abs light and tracktion control lights on ... some say its hubs so have ordered new hubs
    got new head lights cause they look like crap have ordered over 1500 to 2000 in the last week for this thing what a pile of crap .
    oh ya 4th would be ac guy said needs recharged ya not the whole clutch is gone off the compresor so that another 1000 if i do it
    just not impressed with the car so far but man way to deep into it to give up now with all the add ons ive ordered so guess ill fix all and go from there
    anyone else have this many problems with there 05 gxp
  2. #2 Re: pos 05 gxp
    Arizona
    Don't confuse the car with a rigged up car that was in a collision. If you ordered parts for that much you should kick yourself cause you got ripped off. A trip to the junkyard could've got you a set of use able spindles. I have yet to see them ever Crack unless a collision occurred. You need to have the car thoroughly inspected at purchase. And 235 50 18 on a 8 inch rim up front is asinine
  3. #3 Re: pos 05 gxp
    One BadAzz GT Dawgg Mirraco's Avatar
    Aug 2012
    Brainerd, MN
    If you do all the work yourself, power steering line, 30$, new knuckles, i believe are about 70$ each, its 70$ for two front wheel bearings, tie rods are 18$ for two.
    Thats 200$ that I would of put onto the car, and I would of put the stock size tire on the car, and that would of cost me roughly 400 if i buy them online and get them mounted and balanced.
    Ive put struts, shocks, wheel bearings, tie rods, cv axle, brake pads and rotors, sway bar linkage, and when it was all said and done cost me about 700$ after alignment.
    I did same thing with my g6, all the same stuff, just no axle, and that was about 550$.
    If you put 2000$ into the car, you could of bought all the tools needed, even a air compressor, impact gun, all the sockets you need, get it all done yourself and you would have money left over. And would be roughly 100-150$ for headlights, search around before you buy parts, alot of times they are cheaper on ebay, if you go to that ebay sellers actual website, the prices are cheaper sometimes. I use am-auto parts, they seem to be the best priced, othertimes I go elsewhere. Prime choice auto parts is also one I frequent.
    Thats my .02, grand prixs are really easy to work on, it would take me about 3 hours a tire doing all that work.
    Also if your knuckle was cracked in a collision, there will be more damage, if body damage has been fixed, check that side all the suspension parts, i had a GP that hit a embankment, drove it 3 hours home, and learned that one of the axles was shot, boot tore right off of the end part.
    01 GP GT navy blue 70K miles and counting, dd. 17" 05 gtp wheels, 35% tint, 05 heated leather, smoked led tail lights, k+n filter, zzp catted downpipe, 2004 exhaust, roof rails, reptile tune 08 G6 GT coupe 95k miles, racekar. 2 alpine type x 12", two alpine pdx 600 amps, pioneer 8000nex head unit (GPS ), heated leather, autostart.
  4. #4 Re: pos 05 gxp
    GXP Level Member
    Mar 2015
    Tomball
    It's a 10 year old car quite yer *****in'
    seriously you are going to have issues here and there and since it sounds like you don't work on cars, it might be best to sell it and get something new, or a Honda.
    Jeff
  5. #5 Re: pos 05 gxp
    GTP Level Member
    Aug 2012
    st louis park, MN
    Sounds like you bought a mess of a car without looking at any of the mechanicals. Learn to inspect a car before buying it (other than big shiny rims) and learn to work on it yourself.
    2008 Grand Prix Base: Engine cover delete , flipped dogbone bushings, Transgo shift kit, Hayden 403 trans cooler,
    Quote Originally Posted by Yarbeau View Post
    we are all anal about our vehicles. Otherwise we would not be on an extinct platforms forum debating 3000 dollars cars!
  6. #6 Re: pos 05 gxp
    sounds like you need to but buy socket set and a few tools and start working on your own car. or buy or lease something with a warranty. id kick someone in the balls so fast if they wanted 300 bucks to change one of the easy lines
  7. #7 Re: pos 05 gxp
    Aug 2012
    Brainerd, MN
    Quote Originally Posted by ScottyDoggs View Post
    This. If he needs new hubs, he should expect to pay 250-300 each hub, when its only four bolts holding them in.. I saved alot doing my own work, that 25$ mas airflow sensor would of been 200+ at dealer.
  8. #8 Re: pos 05 gxp
    Sounds like your listening to the wrong people.. Abs issues aren't necessarily the hub... Pay and have it scanned first if needed don't just assume it's the hubs. Tire sizes.. Well most go with 245/45 as replacements. Power steering line.. Easy enough fix. New headlights are what $80-90. Get some basic tools and do your own work and you won't be $2k in. It's a 10+ year old car what do you expect.
    04 Comp G.
  9. #9 Re: pos 05 gxp
    Awesome Level Member chrsmi1's Avatar
    Jan 2013
    Raleigh, NC
    Gotta agree. With cars these age you have to be able to do the work on them or its gonna be an arm and a leg. Either way good luck going forward. The forum is a good tool for knowledge so use it.
    Comp G. E85, 2.8, Headers, Tune, Intake, S1X, 105# springs, 60 # injectors, 255 walbro,etc.
    *NEW* 2002 Camaro Z28- Lid, Headers, Catback
  10. #10 Re: pos 05 gxp
    Yup.
    Sounds like you just bought a lemon and got hosed.
  11. #11 Re: pos 05 gxp
    Bastard Reptile's Avatar
    Kansas City, MO
    Quote Originally Posted by blueguy View Post
    Yup.
    Does it? LMAO
  12. #12 Re: pos 05 gxp
    Nov 2013
    Wisconsin!
    Oh man that sounds awful. ....I'll give you a dollar for it and save you all this trouble!! Pm me!!
  13. #13 Re: pos 05 gxp
    GTX Level Member Travisgt2's Avatar
    Jan 2013
    leavenworth ks
    you tube, google and ebay are your best friends
    04 GT2: 180 t-stat, cold air intake, reptile tune, plog, hv3, gt1 cam, 90#springs, new push rods, new lifters, port polished heads, lim, uim and tb, 06 Impala brakes and steel brake lines. Cosmetic: black roof rails, under glow, Pontiac ground light, blue hud dic radio controls and cluster. To come custom hood.
  14. #14 Re: pos 05 gxp
    Donating Users EHB's Avatar
    Dec 2014
    Maryland
    i to bought a money pit ... i feel your pain. but as others have said , it's your fault for not properly looking the car over just as i didn't. trusting the person that is trying to sell you a car is your first mistake.
    i bought mine on a rainy cold december night , so outside of listening to the motor , i didn't look the car over an took the owners word on what he thought was all it needed ... yeah right. he brought the car on a trailer because it had no brakes. he told me previously it just needed brakes and rotors, and had a fuel leak. that was it. all he thought it needed to be on the road.
    when he got there the battery was dead.
    he said the battery was good it's just been setting for awhile...lie number 1 ... the battery would not hold a charge. first $100 went to a new battery.
    put new brakes and rotors on he already put new brake lines all the way around. the entire underneath was a rusty mess. the brake lines rusted apart.
    found the fuel leak. the fuel feed line was squirting gas. it was so rusted it was beyond repair. when trying to take the line off the other two , return and evap , snapped in half. dealer ONLY items about ...............................$460.
    one look at the fuel filler neck told me it wasn't long for this world...$100
    first time i put more than 3 gallons gas in ... found the fuel tank hole ...$160 + straps $30 ?
    fuel filter....$20
    found a leak in the trans coolant line ............................................$ 65 i think it was
    both the head lights and tail light assemblies were full of water and trash... $ cheap ebay headlights..,$67...cheapest tails i could find $129
    power seat wouldn't move bad switch ....junk yard $40
    heater didn't work . blower motor ....$55
    DIC didn't work . ebay junk store used..$42
    front sway bar was broke....................$100
    abs / TC ...replaced two front hubs ...timkens $189
    scanner wouldn't communicate with ecbm ...ebay junk yard ecbm...$100
    had to replace both front abs wire harness .......$60
    all that was even before the routine stuff.
    radiator flush
    plugs and wires
    transmission filter and fluid
    supercharger oil
    O2 sensors
    pcv valve
    oil change
    air filter
    2000 GTP - 3" Catted DP...ZZP Plog...9" Cone filter...Reptile pcm...3.4 pulley...AL104's
  15. #15 Re: pos 05 gxp
    Who is this guy? SubwayGuy's Avatar
    Apr 2015
    Quote Originally Posted by J57ltr View Post
    Jeff
    Not many problems with my '01 GT and that's 14 years old. Once the intake manifd gasket is changed, everything is good on mine, except for the pan, shhhhhhhhhhhh lol.
  16. #16 Re: pos 05 gxp
    Jul 2015
    gridley il
    i am doing alot of the work my self i have a lift and all tools you could ever need just having power steering line done at shop didnt feel like messing with
  17. #17 Re: pos 05 gxp
    This thread title does not deliver...... Wait a minute car still has stock transmission as in it hasn't been replaced. Obviously the rest is minor repairs LOL!!!!
