Thread: Need some serious help before i damage my car.
Page 1 of 8 123 ... LastLast
Results 1 to 20 of 144
  1. #1 Need some serious help before i damage my car.
    Jun 2015
    Spokane Washington
    Hello, thank you for taking the time to read this post.
    Since i got my 2006 grand prix 3.8L from the dealership, my e-brake cables have seized and the dealer took care of it with their mechanic, that is all fine and dandy, but i also mentioned to the mechanic that the car runs hot, 3/4 of the way up on the thermostat when idling and drops slightly when driving.
    Yesterday was the highest i have seen the thermostat go, it went all the way into the red zone and the car was telling me that the coolant is hot. The mechanic told me it is normal and they run hot, the fans are turning on at 3/4 the way up on the thermostat. Which i thought was really weird because every car i have owned has the fans turn on at normal operating temp. the overheating happened when i was in the bank drive through. I don't know what to do at this point, the mechanic said its normal. But i don't really find that normal.
    Any advice would be very appreciated.
    Thank you.
  2. #2 Re: Need some serious help before i damage my car.
    Anything north of 220* is too hot in my opinion.
    Sounds like it needs some work...either the t-stat is on its way to sticking...fans are crapping out...or the thing needs flushed. Either way, running that hot isn't normal.
    Any engine codes?
  3. #3 Re: Need some serious help before i damage my car.
    Enfield, CT
    Mechanic is a liar. Flush coolant, change thermostat, and bleed the system.
    It shouldn't run that hot.
    Sent from my LG G3
  4. #4 Re: Need some serious help before i damage my car.
    Enfield, CT
    Also what's the name of this dealership?
    Sent from my LG G3
  5. #5 Re: Need some serious help before i damage my car.
    Oct 2011
    Toledo, OH
    Fans don't turn on until like 219 degrees, but still sounds like you are running hot. Maybe need a new thermostat and possible have air in the system. Temp sensor only measures coolant in the engine block, and if there is air trapped under the thermostat it won't open to circulate the cooler coolant from the radiator into the engine.
    There is a brass 7mm bleeder screw on the thermostat housing.
    7"
  6. #6 Re: Need some serious help before i damage my car.
    Jun 2015
    Spokane Washington
    Here is the dealership http://clickitautoandrv.com/
    Also, should i tryo to take it to autozone/orileys? I really don't know where any of this stuff is, I have only owned Honda's previous to this 06 GP and it looks like a whole new world really.
    Thank you.
  7. #7 Re: Need some serious help before i damage my car.
    Jun 2015
    Spokane Washington
    Do i just find the bleeder screw and undo it?
    Should i do it when the car has not been running?
    Thanks
  8. #8 Re: Need some serious help before i damage my car.
    Enfield, CT
    Dude that place is a rip-off
    Sent from my LG G3
  9. #9 Re: Need some serious help before i damage my car.
    I would recommend getting a cheap bluetooth adapter and the torque application. This will allow you to see what actual temperature is running.
    Low speed fans should be programmed to come on around 216F and the high speed fans should be ~228F. Yes these cars are programmed to run a tad warm, however that temp on the gauge is typically much lower than you mention. Since gauges can be reporting incorrectly, I suggest the live scanning.
    Also I would suggest looking at the coolant elbows, water pump and radiator for any obvious leaks. Ensure the system is full when cold.
  10. #10 Re: Need some serious help before i damage my car.
    Oct 2011
    Toledo, OH
    Quote Originally Posted by Shawn Rollick View Post
    Thanks
    Open bleeder screw after car is hot, while running. Keep it open until you get a stream of coolant out the side hole instead of sputters of coolant/air. It's going to be hot so use a ratchet with extension etc. You'll probably have to do it again later. While you are doing it, take note if the fans are coming on too. If no coolant ever comes out, than you know the thermostat isn't working.
    7"
  11. #11 Re: Need some serious help before i damage my car.
    Jun 2015
    Spokane Washington
    No engine codes, only the car telling me the coolant is hot when the thermostat was north of 3/4 the way.
  12. #12 Re: Need some serious help before i damage my car.
    Jun 2015
    Spokane Washington
    Quote Originally Posted by industrialfish View Post
    I will try this tonight after work and will post an update. Thank you everyone.
  13. #13 Re: Need some serious help before i damage my car.
    Enfield, CT
    Also if no coolant comes out, you could be really low as well. You should have a strong stream bursting out when you bleed it. Water pump good?
    Sent from my LG G3
  14. #14 Re: Need some serious help before i damage my car.
    GXP Level Member
    Mar 2015
    Tomball
    It should run dead center in the middle of the gauge. If you aren't using the AC and in standing traffic it will get 1-2 tick marks above middle and should cycle back and forth. With the AC and fans on it should stay just a mark below the middle. But scanning is best as Bill said. I'm using a BAFX its $25 bucks and the Torque Pro is $5, but for just doing coolant temp you can just use the free version. There are cheaper ones out there, but bought one and it didn't work on GM cars. I spoke with a few guys at BAFX and they stand by their product. Some have had good luck with others, but it seems like a crapshoot at least the BAFX guys are in the U.S. and they will support it.
    also make sure your overflow bottle is filled properly and that the hose isn't leaking. If you get any air out of the system make sure to keep an eye on the coolant level in the overflow.
    Jeff
  15. #15 Re: Need some serious help before i damage my car.
    Jun 2015
    Spokane Washington
    Quote Originally Posted by J57ltr View Post
    Jeff
    Thank you Jeff for that information.
    Yesterday i did not get a chance to complete anything, i was very busy.
    The car doesn't throw any codes or anything that is why i am so confused.
    Am i able to rule anything out since there is no codes being shown?
    also, could anyone provide a slightly more detailed information on where this bleeder valve is for the air/coolant?
    Thank you.
  16. #16 Re: Need some serious help before i damage my car.
    The bleeder screw is located in the top of the thermostat housing. This is easily located by following the top radiator hose to the engine. Presto..you are at the thermostat housing and the screw is right on top. Usually brass.
    The car will also not throw codes if it is running a bit warm.
  17. #17 Re: Need some serious help before i damage my car.
    Sep 2014
    Worcester, MA
    I'm afraid that if your coolant level is so low that you're losing it... maybe through an intake gasket (although I think your year came with metal gaskets from GM).
    You probably lost a significant amount of coolant for it to heat up so badly, if that's the problem. If your radiator and overflow is full, then you have a flow problem of some kind, and a flush might be a possible solution.
  18. #18 Re: Need some serious help before i damage my car.
    GXP Level Member
    Mar 2015
    Tomball
    The bleeder valve is on the thermostat housing and is brass. It looks like a small bolt in a bolt with a small hole drilled into the side of the larger one. The thermostat housing is the outlet to the upper radiator hose. If the engine is cold just pop the radiator cap off and see if it's full and make sure the overflow is full as well and keep it full. It will go empty and you will end up with air in the system again. You could even have a stuck thermostat that is only allowing a small amount of coolant to pass. I answered a thread where I explained how the system works I will try to find it.
    Jeff
  19. #19 Re: Need some serious help before i damage my car.
    GXP Level Member
    Mar 2015
    Tomball
    Read this thread it will explain how a cooling system is supposed to work.
    http://www.grandprixforums.net/threa...olant+overflow
  20. #20 Re: Need some serious help before i damage my car.
    Enfield, CT
    Quote Originally Posted by bobc455 View Post
    1. My 06 didn't come with the metal LIM gaskets.
    2. Clog or stuck thermostat
    Sent from my LG G3
  1. Gen v damage
    By Anthony Smith in forum General Tech Discussion
    Last Post: 04-12-2013, 08:00 AM
  2. frame damage?
    By SDgrandprixGT in forum Off Topic Discussion
    Last Post: 09-14-2012, 01:19 AM
  3. How could I tell if there has been engine damage?
    By SilvaMan61 in forum General Tech Discussion
    Last Post: 08-25-2010, 07:02 PM
  4. Whats the Damage?
    By MARKS99 in forum General Tech Discussion
    Last Post: 03-26-2009, 05:25 PM
