Thread: 2008 grand prix condenser removal
Results 1 to 14 of 14
  1. #1 2008 grand prix condenser removal
    Nov 2013
    pittsfield ma. 01201
    Can you remove an ac condenser on a 2008 Grand Prix with out removing the radiator. Thanks for any input.
  2. #2 Re: 2008 grand prix condenser removal
    No.
  3. #3 Re: 2008 grand prix condenser removal
    Nov 2013
    Thank You
  4. #4 Re: 2008 grand prix condenser removal
    Buffalo
    I did on my regal. I didn't have to remove the rad out of the car or drain it.....but I did it
    would it be that different ?
  5. #5 Re: 2008 grand prix condenser removal
    Nov 2013
    Thanks for your reply
  6. #6 Re: 2008 grand prix condenser removal
    Buffalo
    I removed the dog bones. Removed the fan shroud assembly. Removed rad support bar. Removed the rad brackets. Disconnected the condensor line. Pushed the rad forward towards motor. Slide the condensor up and out.
  7. #7 Re: 2008 grand prix condenser removal
    GT Level Member mguzzo's Avatar
    Buffalo NY
    the trans lines into the radiator had enough flex to move?
    "Silver Bullet" 98 GTP Coupe: Stock, rust free, and broadsided.
    Old '98 GTP Coupe: VS Cam, 3.0, S2IC, 42.5#, TOGs, N*/LQ4, Corsa. it once ran a 13 flat
    Older '98 GTP Sedan: Pullied, rockered, SSIC, etc. Stock 14.33 @ 96.5 / PB: 13.89 @ 101
  8. #8 Re: 2008 grand prix condenser removal
    Apr 2015
    Columbus, OH
    Trans lines you could tie in a knot if you wanted.
    Top Swapped 01 Imp
  9. #9 Re: 2008 grand prix condenser removal
    Buffalo
    Yup they are attached at some point to a rubber line. Everything was surprisingly easy
  10. #10 Re: 2008 grand prix condenser removal
    Nov 2013
    Thanks Bro
  11. #11 Re: 2008 grand prix condenser removal
    Buffalo NY
    I just did mine over the weekend without fully removing the radiator. The bottom trans line wouldn't come off. I disconnected the top trans line, upper and lower hoses. Took out the fans and pushed it forward enough to sneak the old condenser out and get the new one in. about 4 hrs of work start to stop.
  12. #12 Re: 2008 grand prix condenser removal
    Buffalo
    ^ that's way too much work. Should have stopped by , I just did mine a couple weekends ago. I have all the tools you need to charge it as well. Just buy the refrigerant at big lots. $7 / 12oz can
  13. #13 Re: 2008 grand prix condenser removal
    Buffalo NY
    you have a vacuum pump? I may take you up on your offer to recharge. I loaded a couple cans, it was cool for a couple weeks but not so much.
  14. #14 Re: 2008 grand prix condenser removal
    Buffalo
    Yessir. Just lost my tap for the cans that allows to me to charge via my gauges. So we have to use the dedicated line hose/tap for them. But it has a built in "gauge"
  1. Need help on 94-96 grand prix dash removal
    By pontiacwarrior in forum General Grand Prix Discussion
    Last Post: 03-10-2013, 09:28 PM
  2. How to replace condenser on '99 Grand Prix?
    By rockford86 in forum General Tech Discussion
    Last Post: 01-23-2012, 02:19 PM
  3. Rear speaker removal for a 2008.
    By joeltonya in forum Introductions/Noob Questions
    Last Post: 06-15-2010, 10:14 PM
