Thread: Engine 'cuts out' when i pass people?
Results 1 to 6 of 6
  1. #1 Engine 'cuts out' when i pass people?
    May 2015
    mn
    I can't nessacerily say it's cutting out, but when I go to pass people, so quick acceleration, my SC kicks in but acts as if it's cutting out? It's not just bogging down either. And last night at a stoplight I pressed the gas like I normally would, and it took a quick second to actually go. I've never had this problem before!
    The only things I can think of would be a fuel filter, and plugs? Just had my mass air flow replaced two months ago.
    Any ideas guys? Or any similar situations?
    I really appreciate the help!
  2. #2 Re: Engine 'cuts out' when i pass people?
    GTP Level Member
    Aug 2012
    st louis park, MN
    Clean the throttle body with throttle body cleaner. If this is gummed up it can cause some issues, and since it's a fairly easy process, there's no reason not to try. There should be a how-to floating around.
    Where in MN are you?
    Also, provide detail about what you are driving so the more knowledgeable people can help - model, year, modifications, recent maintenance, etc.
    2008 Grand Prix Base: Engine cover delete , flipped dogbone bushings, Transgo shift kit, Hayden 403 trans cooler,
    Quote Originally Posted by Yarbeau View Post
    we are all anal about our vehicles. Otherwise we would not be on an extinct platforms forum debating 3000 dollars cars!
  3. #3 Re: Engine 'cuts out' when i pass people?
    May 2015
    mn
    Quote Originally Posted by stocker View Post
    Switched to this forum, so that's my fault, just so used to everyone knowing what I drive in the previous one!
    I drive a bone stock 2000 GTP. She's my daily beater 😁
    I'll was thinking that as an option too, guess I'll have to stop and get some before the weekend here.
    But I'm in the Twin Cities.
  4. #4 Re: Engine 'cuts out' when i pass people?
    Donating Users EHB's Avatar
    Dec 2014
    Maryland
    transmission slip ?
    2000 GTP - 3" Catted DP...ZZP Plog...9" Cone filter...Reptile pcm...3.4 pulley...AL104's
  5. #5 Re: Engine 'cuts out' when i pass people?
    Mar 2015
    Ewing NJ
    Get some MAF cleaner as well.
  6. #6 Re: Engine 'cuts out' when i pass people?
    Possible spark plug/wire issue aswell, might be misfiring.
    Maybe even a clogged exhaust from a bad converter, but that's not as common.
    I'm from the rogers area, so not that close to cities.
  1. engine question for you expiernced techs/machinest/smart people
    By joe0813 in forum General Tech Discussion
    Last Post: 12-21-2012, 03:19 PM
  2. Replies: 2
    Last Post: 02-14-2012, 08:47 PM
  3. Engine surges and cuts out
    By timmyg in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-02-2010, 04:26 PM
  4. Engine cuts out
    By DLAVENGER in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-25-2010, 10:07 PM
  5. @115 Engine Cuts out
    By stlmo_gtp in forum General Tech Discussion
    Last Post: 08-23-2008, 09:51 AM
