Thread: Hey first post.
Results 1 to 4 of 4
  1. #1 Hey first post.
    May 2015
    Miami
    I have a 04 grand prix GT and I want to get wide tires but is that even possible? If so what is the max width I can use?
  2. #2 Re: Hey first post.
    Without knowing your time size, I can't tell you exactly.
    But I will tell you what I do know. For 16's stock wheels, 245/50/16's can be done, anything else really wont work or there dont even make a size bigger
    17's, no idea.
    18's, the primany size is 245/45/18. That will fit nearly every rim you'd want to run, rim width and offset will be your other big factors.
  3. #3 Re: Hey first post.
    I break stuff selliott's Avatar
    Kansas City
    Check out the tire and wheels section, it should help
  4. #4 Re: Hey first post.
    Jan 2015
    havelock, ontario canada
    Im running 245/45r18s 2.5 inch offset with stock struts and its about as wide of a tire you can get on the 04 gt.
  1. Do you have to post here before you post in forsale?
    By blank77 in forum Introductions/Noob Questions
    Last Post: 04-10-2013, 03:17 PM
  2. side post to top post conversion
    By arcadeguest in forum General Tech Discussion
    Last Post: 01-12-2012, 01:09 PM
  3. First post!!
    By gtpnutz in forum Introductions/Noob Questions
    Last Post: 05-15-2011, 07:37 PM
  4. First G8 Post =]
    By GTPJOE90 in forum Other Vehicles
    Last Post: 11-04-2008, 07:45 AM
