Thread: New to Pontiac & Forum... Need Help/Advice
Results 1 to 10 of 10
  1. #1 New to Pontiac & Forum... Need Help/Advice
    Apr 2015
    Toledo, OH
    Hello GrandPrixForums. I recently sold my first personally owned GM and hopped into another the next day. I bought a 97 GTP with high miles -160,000- for a price I couldn't pass up. So without knowing the past of the car, I go to an auto parts store and buy pretty much all the things I know need replacement due to the odometer.
    My question is, what are the immediate things I should look at or pay attention to. I can do all the research and locate the pages myself... I am just looking for specfic words to a specific part/area. I guess a couple of examples would be " Owners of 02-06 Dodge Ram with a Cummins should be wary of the Trans imploding if you increase the power" or "GM Trucks tend to burn out the Driver's Daytime Lights" or "The Cam Sensors on a 3.6L Caddy start sending bad readings to PCM ruining performance/mpg but you can remove & clean magnetic half. Avoiding a trip to Autozone" lastly "On 4.0L Jaguars, you should replace the Plastic Timing Chain Guides every 40k & saves thousands in the future." I hope my question and examples make some sort of sense, its been a long day.
    I've owned many vehicles over the years from Porsche 996 to square bodied F250 on 40's Whether it'd be for resale, repair, modification, or maybe looking like a badass if it breaks down when I am with a lady friend (It's happened more than twice) , I like to take as much info about that make and model.
    To Whoever took the time to read and has suggestions or answer(s) to my question. Thank you : )
    - Pictures for credibility, bottom two were in California, before I moved to OH (what a change of "scenery" )
  2. #2 Re: New to Pontiac & Forum... Need Help/Advice
    On a GTP,
    Use Premium fuel only
    Do the plugs and wires, clean the throttle body.
    The trans on these can get sketchy, however if you don't abuse it daily.. it should last
  3. #3 Re: New to Pontiac & Forum... Need Help/Advice
    Sep 2014
    Worcester, MA
    The Lower Intake Manifold gasket is frequently a problem, because people don't change out the antifreeze periodically like they are supposed to, and it turns acidic and eats the plastic gaskets. Replace with aluminum gaskets, and flush out the cooling system. You might also take this opportunity to convert to Ethylene Glycol antifreeze instead of Dexcool, but be sure your flush is thorough because the two don't play well together (unless you go to "universal").
    When I obtain an older car, I like to power wash everything so leaks show up. Valvecover gaskets can sometimes be an issue.
    Rust around the rocker panels can be kinda nasty. So can rust around the strut towers (esp. rear).
    It's quite possible the plugs and wires are still factory original. Especially if you see the cylinder #'s on the spark plug wires (replacements don't have the cylinder #'s printed on the wires). If you go after the lower IM gasket, it would be a good time to do this (and clean the throttle body like Bill suggested).
    When I pick up a GP, I like to throw in Monroe Quick struts and Raybestos Brakes on all four corners. Just a personal preference there.
    Transmission fluid might have never been changed. Many people like to add a shift kit.
    Supercharger coupling can be an issue. Some shops will tell you to replace the whole supercharger for $1300 but you really just need the plastic coupling. And BTW you might want to change out the supercharger oil, good chance it's never been touched. The old stuff has to be sucked out.
  4. #4 Re: New to Pontiac & Forum... Need Help/Advice
    Quote Originally Posted by bobc455 View Post
    Need to disagree with you Bob. If you replace with plastic frame gaskets, it does not matter what type of coolant you use the gaskets will begin to warp and implode. I tested this before metal gaskets were available. In as little as 20K, the gaskets were having issues.
  5. #5 Re: New to Pontiac & Forum... Need Help/Advice
    Sep 2014
    Worcester, MA
    Interesting! In any case, I think we agree that the plastic gaskets should be replaced with aluminum.
  6. #6 Re: New to Pontiac & Forum... Need Help/Advice
    Apr 2015
    Toledo, OH
    Thanks for the suggestions. It looks like I got my weekend planned out for me. The Supercharger oil is available at the dealership?
  7. #7 Re: New to Pontiac & Forum... Need Help/Advice
    Mar 2015
    Ewing NJ
    Some Dealers carry it, some don't. Call Ahead or you can order it from amazon or ZZP...
    http://www.amazon.com/s/ref=nb_sb_ss...up%2Caps%2C177
    You need to order two bottles of the 4oz, it requires 6oz to change, and wear gloves when changing it smells awful.
  8. #8 Re: New to Pontiac & Forum... Need Help/Advice
    Apr 2015
    Toledo, OH
    bobcat455 & to whoever's reads... I did some of the things you suggested. I did spark plugs, wires, pcv valve, fuel filter, battery. I also clean the MAF with that spray. Also the throttle body & a few inches into the plenum. When I looked/bought the car, the battery was not there (I guess I over looked that detail in the small print) I hooked up jumper cables as a last resort and heard/saw it for about 10 seconds. It ran (rough) but started right up and had an instant CEL - MAF low circuit. After doing that work, the car will not run. If I crank and feather the throttle, it sputters and feels like the last 3 seconds before running a gas tank dry. No CEL (of course, it only ran for 1.7 seconds...haha)
    NOTE: I am mechanically inclined. I was apart of a pro Porsche series pit crew. I've made 70% of all my money since my legal working age from some form of the automobile. So someone putting a fuel filter on backwards (why are they arrowed for direction, if they only go one 1 way?) Or not hooking up the throttle cable would be funny.. I don't think I'll be the one this time. I have very little knowledge about engine issue diagnostics, basically I don't **** about it.. Any ideas or comments would be greatly appreciated and the next beer is on me.
  9. #9 Re: New to Pontiac & Forum... Need Help/Advice
    Sep 2014
    Worcester, MA
    At first, that sounds like the time when we had a tank full of bad fuel. We got the engine to fire up when we shot ether into the intake, but couldn't get it to keep running. Eventually we had to dump the fuel and get fresh, then it was fine ever since. (Gasoline companies say that fuel is good for 60 days out of the pump, and even with aftermarket additives they don't like it being used after 90 days... I've exceeded that plenty of times, but if the gas is really old or maybe contaminated with water then you might want to try other fuel)
  10. #10 Re: New to Pontiac & Forum... Need Help/Advice
    Apr 2015
    Toledo, OH
    Thanks for the advice. I ended up tearing the whole top half the engine up replacing the LIM gaskets along with the gaskets of the water pump, timing chain cover, thermostat, supercharger,map, injectors, oil pan and some others. Also dropped the gas tank, put in a 180° thermostat, DIY intake, belts and much more. I am about 90% done and anxious for the start up. I'll let you know how it goes : )
  1. Old Pontiac Owner New to the forum - questions
    By macjoubert in forum Introductions/Noob Questions
    Last Post: 02-07-2014, 09:11 AM
  2. Another NOOB to this forum and my first pontiac
    By kingspadeshan in forum Introductions/Noob Questions
    Last Post: 07-09-2013, 06:49 PM
  3. New to the forum & Pontiac
    By GPmanter in forum Introductions/Noob Questions
    Last Post: 11-22-2011, 03:43 PM
  4. New to Forum and Pontiac
    By TPStatic in forum Introductions/Noob Questions
    Last Post: 11-18-2011, 12:15 PM
  5. help i need your advice on a 04 pontiac grand prix gt
    By snoop2004 in forum General Tech Discussion
    Last Post: 10-25-2011, 12:08 PM
