Thread: "New" from IA with boost issues
Results 1 to 9 of 9
  1. #1 "New" from IA with boost issues
    May 2013
    Iowa
    so I registered 2 years ago to learn a bit when I was buying my 2nd car my 98 gtp. my first car was a 97 regal gs which I still have, at the moment it is faster than my modded gtp because it only gets 4 or 5/10 bars on the boost gauge.
    When I bought my gtp it was very fast and hit all 10 bars, about 6 months later the SC started sputtering and only went up to 5 bars. this car was broken for like another 6 months (fuel pump) recently fixed it, ran fuel injector cleaner thru it and it made a ton of difference. but it still lacks boost.
    mods from the previous owner:
    bored over to 3.9liter
    full 3'' exhaust pacesetter headers and mufflers
    3.4 pully
    160 t stat
    I dont have a garage and dont know how to work on cars yet but I would love to learn. these mods are doing me no good with a boost leak. I plan to read posts and figure this out but Id like to know what the most common reasons for this are or where to start as my mechanic skills are very limited at the moment, I do have friends who might be able to help me. thanks brahs
  2. #2 Re: "New" from IA with boost issues
    Unplug the BBV solenoid and see if the boost returns.
  3. #3 Re: "New" from IA with boost issues
    May 2013
    Iowa
    Ok I read around a bit and I'm going to try this. Just want to make sure I unplug the right line. there is only one line that runs from the actuator to the solenoid right? and thats the one I unplug and cap off, but leave the nipple part of the actuator open?
  4. #4 Re: "New" from IA with boost issues
    Kemmerer, Wyoming
    check the how to section for installing a custom built hot air intake
  5. #5 Re: "New" from IA with boost issues
    GTP Level Member buickman104's Avatar
    NYC
    Install a 195 or 180 degree thermostat. The 160 is too cold.
    2000 Bronze Metallic GTP
    Power :Gen V, 3.6 pulley, 3 inch down pipe, Power log, FWI,and DHP Power Tuner,
    Handling: Vogtland Springs, GMPP sway bars, STBS, 18" Konig backbone, CTS-V Front brakes and GXP rear brakes
  6. #6 Re: "New" from IA with boost issues
    May 2013
    Iowa
    ok. a mechanic told me it is just wasting fuel at 160 so I will do that
  7. #7 Re: "New" from IA with boost issues
    I said unplug the electrical connector going to the solenoid.
    You don't want to cap off or re-route any of the lines.
    That is just a test to see if you "boost" returns, if so, then either you need to buy a new solenoid of the BBV itself is at fault.
  8. #8 Re: "New" from IA with boost issues
    May 2013
    Iowa
    ok im going to try this right now thanks
  9. #9 Re: "New" from IA with boost issues
    May 2013
    Iowa
    I unplugged the solenoid and ran it I hit 6/10 bars. somehow it feels faster but not so much from 50-75. I will try and get a video up. the previous owner told me he replaced the actuator so I doubt that's the problem but I will check it out
  1. 2006 Grand Prix "Reduced Engine Power" and "Service Traction System" warnings
    By chadwick in forum General Grand Prix Discussion
    Last Post: 10-04-2013, 09:59 PM
  2. Issues " Grand Prix GTP not starting correctly "
    By Trump in forum General Tech Discussion
    Last Post: 01-13-2013, 08:54 PM
  3. not making "full" boost
    By 2000GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-01-2009, 03:23 PM
  4. Car "shuttering" under moderate boost?
    By CDoran in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-30-2009, 09:25 PM
