Thread: Intense PCM and p0128 code
Results 1 to 10 of 10
dmack976 Intense PCM and p0128 code 03-28-2015, 09:45 PM
Scottydoggs Re: Intense PCM and p0128 code 03-28-2015, 09:51 PM
dmack976 Re: Intense PCM and p0128 code 03-29-2015, 12:20 AM
dmack976 Re: Intense PCM and p0128 code 03-29-2015, 12:28 AM
Scottydoggs Re: Intense PCM and p0128 code 03-29-2015, 12:36 AM
dmack976 Re: Intense PCM and p0128 code 03-29-2015, 01:24 AM
SgtMarshal Re: Intense PCM and p0128 code 03-29-2015, 07:16 AM
dmack976 Re: Intense PCM and p0128 code 03-29-2015, 02:37 PM
dmack976 Re: Intense PCM and p0128 code 03-29-2015, 01:42 PM
Scottydoggs Re: Intense PCM and p0128 code 03-29-2015, 01:50 PM
  1. #1 Intense PCM and p0128 code
    Palmdale
    Having issue with the.check engine light turning.. I installed a intnese pcm and 180 thermostAt .. getting a p0128 code. Bleed the system, topped.off fluids .. could this be the radiator sensor , bad radiator cap or bad program??any help would be nice. Going to replace the thermostat..
  2. #2 Re: Intense PCM and p0128 code
    160 is to cold put a 180 or a 195 in there.
    i got my fans tuned to 180 and i have a 195 t stat, temps have been under 195 a lot. even in stop and go traffic.
    you dont really want your car running cold, this is not a old school car, it runs off a computer. GM made it to run at 200 to 210 all day long.
  3. #3 Re: Intense PCM and p0128 code
    Palmdale
    I talked to orielys and they said I.bought a 180... so I was wrong.when.I.said 160
  4. #4 Re: Intense PCM and p0128 code
    Palmdale
    I edited my post. Im running a 180 thermostat. Its quite possible he missed programmed my PCM. Cant think of any other reasons why the code keeps comming back
  5. #5 Re: Intense PCM and p0128 code
    well the t stat could be defective. or its to cold still at 180.
    you got a t app? or any other scanner to see the temps?
  6. #6 Re: Intense PCM and p0128 code
    Palmdale
    I am thinking the t stat is defective. I have a areforce scan gauge and i am showing temps 176 and no higher. My old tstat is a 195, should i put that one and just run the 195?
  7. #7 Re: Intense PCM and p0128 code
    Kemmerer, Wyoming
    the engine will make more power if it runs colder, but if its cold all the time than it will burn more fuel and the heater wont make as much heat. a new thermostat is literally 10 bucks, but if you want to reuse your old 195, that is your choice.
  8. #8 Re: Intense PCM and p0128 code
    Palmdale
    Problem solved for now.. no pending check engine and no check engine light. the new t stat I put in was not bad. When I checked my scan gauge nothing comes up
  9. #9 Re: Intense PCM and p0128 code
    Palmdale
    The t Stat I put in it was brand new .. the 180. Seems like no one thinks it could be the program
  10. #10 Re: Intense PCM and p0128 code
    ive told ya like 5 times easy to change that t stat. they come defective brand new some times. like any part you buy.
    if you take it out and its locked open, well by golly you now know its bad. most fail safe in the open position.
  1. P0128 code
    By squirt in forum General Grand Prix Discussion
    Last Post: 11-21-2014, 09:27 PM
  2. P0128 code
    By TDgrand in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-24-2013, 09:33 PM
  3. repair code p0128
    By dnomaam1 in forum 3.1L V6 (LHO/LG8)
    Last Post: 12-10-2011, 12:28 AM
  4. Getting P0128 code in the summer
    By picghaw in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-26-2011, 11:42 PM
  5. Code P0128
    By trenaro in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-28-2010, 08:38 PM
