Thread: Wheel Bearing hub
Results 1 to 7 of 7
  1. #1 Wheel Bearing hub
    Palmdale
    So the guy that owned the car before decided to cut the front passenger side wheel bearing hub wire. I replaced the Wheel bearing with Timkens ... the driver side is hooked up. but i am not sure where the wire is or leads up to or even starts on the passenger side. If anyone can help me find a diagram or lead me to where this other wire is that would be great. Even better yet I will need the connector. I can get one from the junkyard to but still need to know where it starts.
  2. #2 Re: Wheel Bearing hub
    St. Louis
    Should just run along the control arm and towards the front of the car where it joins the other harness.
  3. #3 Re: Wheel Bearing hub
    the pass side hubs harness crosses the lca, then up to the plastic shield through a slot in it in, on the other side by the harmonic balancer is where its plug should be. right where the main harness is that leads into the cars cab.
    you can buy that hub to main harness, harness if you dont see it there.
    chances are it got torn off, not cut. and the po just didnt give a crap.
  4. #4 Re: Wheel Bearing hub
    Jan 2014
    AR
    If the wire got yanked off which I agree is most likely, more of it may be gone. The control arm harness does stop at a connector on the subframe, easily seen as mentioned. It goes into the harness below the radiator after the connector, so look for something hanging out there if the connector and clip are missing. You may need a replacement "pigtail" and I don't know the availability of those.
  5. #5 Re: Wheel Bearing hub
    i got a place on ebay that can and will make you any gm pig tail, if they dont have it listed, you just ask them for what you want. they will make the pig tail as long as you like too.
  6. #6 Re: Wheel Bearing hub
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    I dont think all cars had the shorter pigtail off the hub I know mine didn't.
    2012 F150 STX
    - Gonna be a race truck
  7. #7 Re: Wheel Bearing hub
    ive only seen it on the pass side, yet to find a plug on the driver side. but you can still buy that harness and splice it in. dorman sells that part. for both sides.
  1. shaking steering wheel after wheel bearing replacement
    By vandezand in forum General Tech Discussion
    Last Post: 05-14-2014, 04:02 PM
  2. Wheel rocking still... already changed wheel bearing. Ideas?
    By jmn in forum Introductions/Noob Questions
    Last Post: 09-30-2013, 09:27 AM
  3. wheel bearing
    By mosley in forum General Tech Discussion
    Last Post: 04-04-2011, 08:16 PM
  4. ABS wheel bearing/hub on non ABS car?
    By Captain Bravo in forum Brakes/Suspension/Chassis
    Last Post: 01-01-2011, 03:15 PM
  5. Possible bad wheel bearing?
    By Cail in forum General Tech Discussion
    Last Post: 09-01-2010, 12:32 PM
