Thread: Oild dipstick handle broke.
Results 1 to 6 of 6
CDooley Oild dipstick handle broke. 01-20-2015, 11:20 PM
Scottydoggs Re: Oild dipstick handle... 01-20-2015, 11:22 PM
Fivefingerdeathpunch Re: Oild dipstick handle... 01-20-2015, 11:23 PM
CDooley Re: Oild dipstick handle... 01-20-2015, 11:27 PM
Scottydoggs Re: Oild dipstick handle... 01-20-2015, 11:51 PM
Turbocharged400sbc Re: Oild dipstick handle... 01-21-2015, 08:00 AM
  1. #1 Oild dipstick handle broke.
    Nov 2011
    Virginia
    So I noticed a leak in my front valve cover, so went to check my oil. Part of the handle broke off in the tube, not the entire dipstick. But it's a yellow piece of I think cork that is lodged in there. Any idea how to get this out? And if I can't how easy is it to replace the entire tube myself?
  2. #2 Re: Oild dipstick handle broke.
    when mine broke off in there i used the dip stick to get it out, its got a slot in he middle.
    if need be the tube is bolted to the front manifold stud. take the nut off, pull the tube up.
  3. #3 Re: Oild dipstick handle broke.
    Most dipsticks have a curve/twist at the bottom and should pull the piece out with it. I see it all the time at my work.
    That you stick it back through the broken piece and spin it out while pulling the dipstick out.
  4. #4 Re: Oild dipstick handle broke.
    Nov 2011
    Virginia
    Yea that's the first thing I tried, ended up pushing it further down shen I finally got the thick through it. Now after working at it the stock just goes right through it. Switched to a flat head and it just isn't budging. I'll need to drain my oil when I replace the tube right?
  5. #5 Re: Oild dipstick handle broke.
    nope. un bolt it pull it up and out.
  6. #6 Re: Oild dipstick handle broke.
    hangover park IL
    push the pin most of the way out of the handle and you can take it off yer stick and put the handle from any LSx/3800/3400/3100/etc dipstick on it from the junkyard.
    i paid 5$ for 4 of em last time i restocked my supply.
    i think im gonna get an aluminum LSx type dipstick handle off ebay for my waGN since the handle is 3" from my headers
    ~James~ Psychotic Gearhead
  1. Dipstick
    By tomtom123 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-20-2014, 10:17 AM
  2. 04 Glove Box Handle Broke
    By hammerline81 in forum General Grand Prix Discussion
    Last Post: 12-01-2013, 11:31 AM
  3. Oil Life after 240K..... how many miles between oild changes?
    By Haulero in forum General Grand Prix Discussion
    Last Post: 01-02-2013, 04:47 PM
  4. Driver's side outside door handle broke
    By jokyfo in forum General Tech Discussion
    Last Post: 05-06-2012, 11:10 AM
  5. Now that's using your dipstick......
    By alkygto in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-09-2012, 06:38 AM
