Here goes another noob question. What kind of cat do I run with headers? Speed daddy's more specificly. Can I just reuse my current cat since it's fairly new?
If it is a OEM replacement cat it will not work. You will need a cat with a 3" inlet and outlet.
in the pics it looked like he cut the pipes back into the cat body some where its more open.
hes in ca. a real 3 inch cats gonna cost him. if you can even find a real 3 inch carb cat.
you can get a high flow 3 inch cat off ebay for like 50 shipped. they are on there you need to look around.
but those cats set the check engine light most of the time. depending on your year car a simulator will work, newer cars its a 50/50 shot if it works.
TOGs are carb compliant?
Learn new stuff everyday
