Thread: Couple of quick questions
Results 1 to 10 of 10
  1. #1 Re: Couple of quick questions
    I'd just replace the whole compressor, special tools are required to replace the AC pulley/bearings. And in the end you still have a compressor that is 16+ years old and could choke out at any time.
    They sell bulbs for the cluster, remove and replace should fix it.
    Pics of the subframe spots??
    I have a feeling it's not the subframe, as that is the large metal square that holds the motor/trans to the bottom of the car.
  2. #2 Couple of quick questions
    SE Level Member SpecialK's Avatar
    Dec 2014
    Milwaukee
    Thanks. Here is where the rust is. It's underneath where my hand is. Whatever metal that runs alongside and under the car I believe which would be below the rockers. I'm no mechanic so sorry it that sounds confusing.
  1. Couple quick questions
    By Timing in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-22-2012, 06:30 PM
  2. couple of quick questions about tstats
    By pontiacgp759 in forum General Tech Discussion
    Last Post: 02-02-2010, 11:05 AM
  3. couple of questions, couple of issues
    By zero in forum General Tech Discussion
    Last Post: 12-30-2009, 04:48 PM
  4. A couple of questions.
    By Enjoijoe in forum General Tech Discussion
    Last Post: 04-12-2009, 07:56 PM
  5. couple of quick downpipe questions.
    Last Post: 03-18-2009, 07:36 PM
