Thread: 3800 Monte Carlo
Results 1 to 6 of 6
  1. #1 3800 Monte Carlo
    Jan 2015
    Minnetonka MN
    Hello guys, I'm Neal Hanson and have been working on my natural aspired 3800. I have some questions for you. So far what have done is had the block bored to 20000 thoudnds over and put in JE Forged pistons (flat top) and rings. H-Beam connecting rods. Crank ground and hardened. X-P Hot cam. Removed the balance shaft and filled the gullys Put on double timing chain set. New oil pump with machined cover. New timing cover. I have ZZP heads stage 3 with the multi layer metal head gasket to put on. What kind of rockers should I use? LS7 lifters. L36 supercharger kit. would the 33# injectors be right for this set up? ZZP Headers with egr delete. What size down pipe should i use? No cat but what would be good to use for exhaust after the down pipe? Should i run an inner cooler? What kind of spark plugs should i run? The super charger has the 3.8 pully can i go smaller and how much? What are your thoughts on this build any concerns? Any tips or suggestions?
    Thanks again.
  2. #2 Re: 3800 Monte Carlo
    GrandPrix Junkie
    St. Louis
    Not sure on your experience level with the GM 3800, but did you assemble the shortblock yourself or have a machine shop do it? If you didn't have it align bored and whatnot then you may end up with the "200-mile motor". Meaning it will grenade itself in under 200 miles. The bottom ends on these motors are tough/expensive to get rebuilt properly, which is why most just get a used one and go from there. Rebuilding one of these properly isn't like a Chevy 350.
    You could run an intercooler. You want the hottest spark you can get w/o seeing KR (knock). I would stick with the 3.8 pulley until you have the ECM tuned for the top swap. Even stock the S/C cars have knock. With a top swap you raise the compression which makes it that much more prone to knock. You need an Aeroforce or another way to scan the motor to see what the knock is, among other things. Once you have it tuned good, then consider dropping pulleys. If not then you could end up just chipping pistons and trashing the motor all over again.
    If you haven't read the "Safely modding your 3800" thread on here, that would be an excellent place to start to answer your questions.
  3. #3 Re: 3800 Monte Carlo
    In order to use rockers you would have to mil down the valve guides since you are running a cam already. I would go for at least 42s if not 60s just to give a little more headroom in case you decide to go further. I would go for the 304 stainless off road pipe with the 3" outlet and mate it to ZZPs 3" stainless catback.
    And as Fordman stated read over this thread http://www.grandprixforums.net/threa...00-Powered-Car!!
  4. #4 Re: 3800 Monte Carlo
    Hey there.. your cheapest way to your goal is likely going to be a turbo and rocking transmission. The goal isn't impossible, but it's going to take a few of the big boy mods.
  5. #5 Re: 3800 Monte Carlo
    Jan 2015
    Minnetonka MN
    And thanks for everybody for replying, been working a ton, had no time and I had issues getting logged on.
  6. #6 Re: 3800 Monte Carlo
    Jan 2015
    Minnetonka MN
    Slick2500, when you said: "In order to use rockers you would have to mil down the valve guides since you are running a cam already."
    were you refering to some sort aftermarket ratios or that in order to even run the stock rockers that I would need to mill the valve guides?
  1. Monte Carlo SS?
    By REDCRAPGP in forum General Grand Prix Discussion
    Last Post: 10-24-2013, 10:34 AM
  2. 05 monte carlo rack to 97 monte carlo
    By l67ss in forum Brakes/Suspension/Chassis
    Last Post: 12-23-2012, 12:16 AM
  3. 03 Monte Carlo SS
    By dbrincefield in forum For Sale - Vehicles
    Last Post: 07-16-2012, 07:40 PM
  4. '96 Monte Carlo Z34
    By Condor120 in forum Pre-1996 4 speed Automatic (4T60E)(4T60E-HD)
    Last Post: 05-29-2011, 07:34 AM
  5. GP vs. Monte Carlo (SS?)
    By Deimos in forum Track Sessions and Kills
    Last Post: 03-26-2010, 12:02 PM
