Thread: Solution to rusted out gas cap
Results 1 to 14 of 14
efrench9 Solution to rusted out gas cap 01-05-2015, 02:38 AM
Turbocharged400sbc Re: Solution to rusted out... 01-05-2015, 07:50 AM
GTPpower Re: Solution to rusted out... 01-05-2015, 09:24 AM
Elite6 Re: Solution to rusted out... 01-05-2015, 09:25 AM
Fivefingerdeathpunch Re: Solution to rusted out... 01-05-2015, 11:41 AM
Bronco Boy Re: Solution to rusted out... 01-05-2015, 12:00 PM
stocker Re: Solution to rusted out... 01-05-2015, 03:36 PM
Bronco Boy Re: Solution to rusted out... 01-05-2015, 04:14 PM
efrench9 Re: Solution to rusted out... 01-06-2015, 10:12 AM
Scottydoggs Re: Solution to rusted out... 01-06-2015, 10:14 AM
BillBoost37 Re: Solution to rusted out... 01-06-2015, 10:32 AM
K Slice Re: Solution to rusted out... 01-07-2015, 09:23 PM
BillBoost37 Re: Solution to rusted out... 01-08-2015, 08:09 AM
K Slice Re: Solution to rusted out... 01-08-2015, 10:42 AM
  1. #1 Solution to rusted out gas cap
    SE Level Member efrench9's Avatar
    Jan 2015
    2001 GTP coupe has a manufacturer fault with a falling gas cap cover and I'm looking for an easy fix for it
  2. #2 Re: Solution to rusted out gas cap
    hangover park IL
    step one, remove radiator cap.
    step two, slide new car under radiator cap, reinstall cap
    ~James~ Psychotic Gearhead
  3. #3 Re: Solution to rusted out gas cap
    May 2008
    Schuyler, NE
  4. #4 Re: Solution to rusted out gas cap
    Cambridge, Ontario Canada
    Quote Originally Posted by efrench9 View Post
    High powered magnets if you want easy
    2005 E55 - stock
  5. #5 Re: Solution to rusted out gas cap
    It's a 14 year old part, how is it the manufacturers fault??
    Buy a new cap and be on your way.
  6. #6 Re: Solution to rusted out gas cap
    Jul 2010
    Coquitlam,BC,Canada
    .....falling gas cap cover.....
    I think he/she means fuel door cover.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  7. #7 Re: Solution to rusted out gas cap
    GTP Level Member
    Aug 2012
    st louis park, MN
    Then the OP needs to specify what the problem is. Whether it is falling, failing or the cap, cover door - the problem shouldn't be open to interpretation by people trying to help. Buy a new cap or cut the cover door off. Both are easy solutions and cheap.
    2008 Grand Prix Base: Engine cover delete , flipped dogbone bushings, Transgo shift kit, Hayden 403 trans cooler,
    Quote Originally Posted by Yarbeau View Post
    we are all anal about our vehicles. Otherwise we would not be on an extinct platforms forum debating 3000 dollars cars!
  8. #8 Re: Solution to rusted out gas cap
    Jul 2010
    Coquitlam,BC,Canada
    Quote Originally Posted by stocker View Post
    Ha-ha, ok. Maybe his problem is a bad rad cap, so post #2 is no good. LOL
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  9. #9 Re: Solution to rusted out gas cap
    Jan 2015
    Y'all need to chill on me
    Thanks for the magnet idea
  10. #10 Re: Solution to rusted out gas cap
    why not go get a new door off a junk yard car.
  11. #11 Re: Solution to rusted out gas cap
    If it's a door..
    Maybe it's a window
  12. #12 Re: Solution to rusted out gas cap
    GT Level Member K Slice's Avatar
    Jul 2013
    Traverse City MI
    Mine was sagging because one of the hinge pins for the door had broke due to rust. I took the door and hinge off, hammered out the old pins and made some new pins for it with the leftover part of a cloths hanger. Lubed it all up and it's good as new.
  13. #13 Re: Solution to rusted out gas cap
    You guys do know that the fuel door is held on with two 10mm nuts, don't you?
  14. #14 Re: Solution to rusted out gas cap
    Jul 2013
    Traverse City MI
    I know that..
  1. Aux Input Solution
    By SNeitzel in forum Audio, Security & Visual Electronics
    Last Post: 04-23-2016, 05:43 PM
  2. HID Help? Anyone have a solution?
    By szalajka05 in forum Visual/Body Modifications
    Last Post: 12-04-2011, 03:05 PM
  3. Better solution to a gasket?
    By corsagtp in forum General Tech Discussion
    Last Post: 03-21-2010, 08:26 PM
  4. A non welding solution
    By Mad Monkey in forum Off Topic Discussion
    Last Post: 09-23-2009, 02:22 PM
  5. IAT solution
    By gotboost3 in forum General Tech Discussion
    Last Post: 02-12-2009, 10:11 PM
