Thread: brake bleeding question
Page 2 of 2 FirstFirst 12
Results 21 to 29 of 29
  1. #21 Re: brake bleeding question
    you can use compression fittings. ive used them all over my cars in the past, tranny lines, fuel lines, brake lines. many here frown upon them. ive yet to have one fail to this day.
    i got two on my car now, rear brake line took a crap on me. replaced a 5 foot section.
  2. #22 Re: brake bleeding question
    Donating Users EHB's Avatar
    Dec 2014
    Maryland
    no doubt. i had a leaking pipe on a water line feeding my bath tub and slapped a compression fitting on it as a "temporary fix"...that was 10 years ago...lol
  3. #23 Re: brake bleeding question
    Dec 2014
    Maryland
    it sucks pissing that much money on it, but at least when its done i shouldn't ever have to worry about fixing a leaking fuel line on it ever again...so there's that.
  4. #24 Re: brake bleeding question
    Dec 2014
    Maryland
    look for them yellow plugs.
    these cars the windshield cowl leaks, then leaks in the car, on the fan and its resistor, and floods the pass side floor board. where the air bag module it. so thats how all 3 of them things can go bad. 3 or 4 stones at once maybe on this one.
    http://www.grandprixforums.net/threa...ter+floorboard
    almost forgot to say thank you much for the heads up on the water leak thing. i ordered the deflector and a cabin filter from amazon.
  5. #25 Re: brake bleeding question
    you got it. that thing leaks on all our cars. cheap enough to fix it tho.
  6. #26 Re: brake bleeding question
    Dec 2014
    Maryland
    the car didn't even have a cabin filter in it.
  7. #27 Re: brake bleeding question
    you ask for a cabin filter for a 97-94 regal. gps just didnt come with them for some reason.
  8. #28 Re: brake bleeding question
    Dec 2014
    Maryland
    this is the one i bought. i hope it fits..according to amazon it does.
    This fits your: 2000 Pontiac Grand Prix
    Your Garage (1)
    Notes: Under Hood / Cowl, Medium (10-20 min.)
    See all products that fit this vehicle
    Premium Guard PC5245 Cabin Air Filter
    brake bleeding question Attached Images
  9. #29 Re: brake bleeding question
    Dec 2014
    Maryland
    well we just put the new fuel feed line in ... then the return line started squirting gas every where right at the bends by the fuel filter and on top of that the fuel evaporation line broke off right at the coupler . now i have to order and replace both of those lines ..$ 205.17 with shipping....i've bought a freakin money pit...
    the after market tail lights i bought don't fit right, so it looks like i'll be drilling new holes, the drivers side light sits at an angle and needs to be dropped about 3/4 of an inch on the inside to look level.. the passenger side light isn't off as much but still is off....
    2000 GTP - 3" Catted DP...ZZP Plog...9" Cone filter...Reptile pcm...3.4 pulley...AL104's
  1. Question on bleeding CTS-V Brakes
    By 92builtbird in forum Brakes/Suspension/Chassis
    Last Post: 09-12-2014, 07:18 PM
  2. brake part question not completely noob question!!
    By Lastremanent in forum Introductions/Noob Questions
    Last Post: 06-11-2013, 05:18 AM
  3. Bleeding a 3.1L
    By Matt Beauchamp in forum 3.1L V6 (LHO/LG8)
    Last Post: 05-13-2012, 04:37 PM
  4. Brake Bleeding Procedure
    By SJAndrew in forum Brakes/Suspension/Chassis
    Last Post: 08-12-2010, 06:20 PM
  5. 1992 Grand AM Brake Bleeding help
    By rmacinc in forum Brakes/Suspension/Chassis
    Last Post: 01-23-2009, 09:51 AM
