Thread: over torqued intake bolts
Results 1 to 9 of 9
krsdadsps over torqued intake bolts 11-26-2014, 06:27 PM
blueguy Re: over torqued intake bolts 11-26-2014, 06:29 PM
Scottydoggs Re: over torqued intake bolts 11-26-2014, 06:40 PM
blueguy Re: over torqued intake bolts 11-26-2014, 06:41 PM
Scottydoggs Re: over torqued intake bolts 11-26-2014, 06:43 PM
krsdadsps Re: over torqued intake bolts 11-26-2014, 06:53 PM
krsdadsps Re: over torqued intake bolts 11-26-2014, 06:52 PM
Scottydoggs Re: over torqued intake bolts 11-26-2014, 07:22 PM
ItHurtz Re: over torqued intake bolts 11-26-2014, 08:05 PM
  1. #1 over torqued intake bolts
    Nov 2014
    winston salem,nc
    i over torqued my lim bolts, i knew the stock specs but i installed the aluminum gaskets, i went to 80inch pounds, shound i worry?
  2. #2 Re: over torqued intake bolts
    I never torque spec'd my intake bolts or blower bolts...only worry about the plastic UIM if you're not supercharged.
    Never had an issue.
  3. #3 Re: over torqued intake bolts
    how did you not break a bolt or two, or tree? lol
    if nothing stripped out or snapped, hell leave it be.
  4. #4 Re: over torqued intake bolts
    You just work on enough of them to know when to not hulk smash the ratchet, breh.
  5. #5 Re: over torqued intake bolts
    i mean the op, 80 inch is over 3 times the normal torque.
  6. #6 Re: over torqued intake bolts
    Nov 2014
    winston salem,nc
    what are ever the specs for the upgraded aluminum gaskets? i looked everywhere for them
  7. #7 Re: over torqued intake bolts
    Nov 2014
    winston salem,nc
    i was pissed when i done it lol i bought $700 worth of parts, installed them and the lim was dumping water in the motor, took pff the uim and went to town, should of walked away haha
  8. #8 Re: over torqued intake bolts
    13 or 15 iirc
    upper for a sc was like 17 or 19 not sure off hand.
  9. #9 Re: over torqued intake bolts
    Antioch, IL
    80 in lb is 6.6 ft lbs so ur way under torqued. 180inch lb is what you want.
    2009 Challenger SRT8
    Expert at being gay.
  1. lower intake and supercharger bolts.
    By crashmydaytona in forum Wanted To Buy - Parts
    Last Post: 10-21-2014, 03:44 PM
  2. 2003 Impala 3.4 intake manifold bolts
    By Dadillac in forum General Grand Prix Discussion
    Last Post: 06-19-2014, 08:54 PM
  3. Intake Manifold Bolts Required 01 Pontiac Grand Prix Gt
    By trapperlarry in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-28-2012, 07:31 AM
  4. Intake and supercharger bolts
    By KCase06 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-27-2011, 04:22 PM
