Thread: tried to remove drl fuse...
Results 1 to 8 of 8
  1. #1 tried to remove drl fuse...
    GT Level Member Pontiac Racer's Avatar
    Sep 2014
    U.S.A
    removed it so my lights would only come on at night. put the spare fuse in the fuse box in the engine. started the car then the lights started to flicker and there was a clicking noise that would not stop. flipped the nob to on for the lights and same thing. looks like ill always have drl
  2. #2 Re: tried to remove drl fuse...
    Search brah.
    It's because you have a 01+ car. Only 97-00 can pull the fuse, and when you pull the fuse you have only manual lights, no DRL or auto on.
    Unplug the heatsink and re-install the fuse, I think that will fix your problem.
  3. #3 Re: tried to remove drl fuse...
    Banned
    Jan 2013
    Colorado
    this guys threads are just fantastic
  4. #4 Re: tried to remove drl fuse...
    Sep 2014
    U.S.A
    i like to think my threads are fantastic too
  5. #5 Re: tried to remove drl fuse...
    Quote Originally Posted by Pontiac Racer View Post
    Don't fool yourself. You have a little more learning to do before we'll label them good, fantastic is a few steps up from that.
    Now....my posts...This is how you should treat ...my posts >>
  6. #6 Re: tried to remove drl fuse...
    Sep 2014
    U.S.A
    i put the fuse back in and it stopped. do you know whats different about an 01 and 00 that it would do that?
  7. #7 Re: tried to remove drl fuse...
    Dec 2012
    Where 4T65E's were born
    Not sure technically. Just unplug the resistor with an aluminum heatsink for the DRL's. It's inside the small access door on the drivers side in the dash.
    Sold.
  8. #8 Re: tried to remove drl fuse...
    I Write E85 Stickies Frosty's Avatar
    Apr 2011
    South Dakota
    ^Heatsinks
    "Lets just throw more boost at it and see what happens" -Frosty
    The Defacto Guide to tuning your car for E85. Read it and learn.
    I love Decker<3
  1. ECU fuse
    By cmiranda in forum General Tech Discussion
    Last Post: 10-08-2013, 08:42 AM
  2. Fuse tap for wiper fuse.
    By Stormhaven in forum Audio, Security & Visual Electronics
    Last Post: 07-11-2013, 12:24 PM
  3. How to remove a maxi fuse.
    By Russosaur in forum General Tech Discussion
    Last Post: 05-01-2013, 02:42 PM
  4. Fuse Box
    By Toasty in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-25-2009, 06:10 PM
