Thread: Help with random switch i found
Results 1 to 5 of 5
  1. #1 Help with random switch i found
    Oct 2014
    North carolina
    Hey guys im new here im a big jeep guy not a prix guy and i know with maybe alot more searching i could have found my answer but... I got an 02 geand prix gt 90k miles of michigan winters still solid as can be. Hanging by the my gas and brake pedal i have a little red push button that just dangles it doesnt do anything when pressed so i traced it and the ground it cut but the hot wire runs into the engine bay and under the plastic 3800 shield. And is tapped into a yellow wire and ideas what this could be?
  2. #2 Re: Help with random switch i found
    GT Level Member TwiztdWun's Avatar
    Feb 2013
    Ohio
    Its not factory whatever it is.....could be an aftermarket valet button, something to do with remote start/alarm, extra lights someone added, some sort of fuel pump booster, the possibilities are endless.
    Official GPF Red Neck
  3. #3 Re: Help with random switch i found
    Pics of where the hot wire is tapped in would be of most use to us.
  4. #4 Re: Help with random switch i found
    Oct 2014
    North carolina
    Yeah sorry forgot to post the pictures
  5. #5 Re: Help with random switch i found
    Oct 2014
    North carolina
    So i traced the push button up to a electrical junction box up under the steering wheel where it was plugged in with a little blue plug. And then there was a larger group of wires also plugged in there in which there was a red and blue wire that came threw the firewall one going to the yellow wire i previously talked about and the other was not connected to anything
  1. Found a random taped off vacuum line, help please?
    By JayHerlth in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-13-2014, 02:23 PM
  2. Installing Ignition switch, found something odd...
    By blackflag in forum General Tech Discussion
    Last Post: 02-27-2012, 06:56 PM
  3. Trans switch/ e brake switch
    By Halbs in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-20-2010, 02:57 PM
  4. Random HUD
    By cmw1876 in forum General Tech Discussion
    Last Post: 03-19-2009, 09:35 PM
  5. Found This Joke. Also Found It Amusing.
    Last Post: 12-05-2008, 04:25 AM
