Thread: '01 Grand Prix GT Transmission problems?
Results 1 to 13 of 13
  1. #1 '01 Grand Prix GT Transmission problems?
    GT Level Member Pontiac Racer's Avatar
    Sep 2014
    U.S.A
    i have a 2001 grand prix gt and when i accelerate from a slow speed, you can hear a whining noise. the second i let my foot off the gas, the noise goes away. what is it? also if i floor my car the car shifts rough at 4000+ rpm. it doesn't do it every time, about half. is my transmission going bad. what parts are wrong with it?
  2. #2 Re: '01 Grand Prix GT Transmission problems?
    check the fluid yet? is it full, is it red still?
  3. #3 Re: '01 Grand Prix GT Transmission problems?
    Sep 2014
    U.S.A
    yes, its red. when the car is turned off the fluid is in the squiggle part of the dip stick but i haven't checked it while its running
  4. #4 Re: '01 Grand Prix GT Transmission problems?
    check it hot and running in park on level ground car off tells nothing about its level.
  5. #5 Re: '01 Grand Prix GT Transmission problems?
    Sep 2014
    U.S.A
    its red and its in the squiggle part of the dip stick while the car is shut off. haven't checked it while its running though
  6. #6 Re: '01 Grand Prix GT Transmission problems?
    Trans must be checked while running and hot...........
  7. #7 Re: '01 Grand Prix GT Transmission problems?
    Sep 2014
    U.S.A
    will go do that now
  8. #8 Re: '01 Grand Prix GT Transmission problems?
    Sep 2014
    U.S.A
    the fluid is just under the third circle on the dip stick so its good on fluid. what else could it be. car only has 120,500 miles on it
  9. #9 Re: '01 Grand Prix GT Transmission problems?
    it should be at the top hole, read the stick, it says hot and cold. both have a line.
  10. #10 Re: '01 Grand Prix GT Transmission problems?
    Sep 2014
    U.S.A
    its pretty damn close. i don't think adding maybe a cap full of fluid will make a difference....
  11. #11 Re: '01 Grand Prix GT Transmission problems?
    you sure the power steering pumps not low on fluid. it will also whine when low on fluid.
    if it whines from the driver side of the car, thats the trans pump. not good either.
  12. #12 Re: '01 Grand Prix GT Transmission problems?
    Sep 2014
    U.S.A
    i can't remember but ill drive it tomorrow and see if i can hear it then ill let you know
  13. #13 Re: '01 Grand Prix GT Transmission problems?
    I er uh..didn't check things correctly. so maybe I have an issue....
    lol c'mon guy... pay attention and at least follow normal checking procedures
  1. grand prix transmission problems
    By brentwilliamsm in forum Introductions/Noob Questions
    Last Post: 07-12-2012, 07:08 AM
  2. NEED ADVISE for 94 Grand Prix SE Transmission
    By Kanki in forum General Grand Prix Discussion
    Last Post: 03-23-2012, 03:36 PM
  3. 04 grand prix gt1 n/s transmission
    By PALMCASTER GT1 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-27-2012, 11:46 AM
  4. Transmission issues on 98 grand prix gt...
    By neracer21 in forum General Tech Discussion
    Last Post: 08-22-2010, 12:22 PM
  5. 1994 Grand Prix Transmission Help!
    By mfalk22 in forum Pre-1996 4 speed Automatic (4T60E)(4T60E-HD)
    Last Post: 08-25-2008, 11:41 AM
