Thread: Can a fuel pump from a GTP work on a GT?
Page 3 of 6 FirstFirst 12345 ... LastLast
Results 41 to 60 of 106
  1. #41 Re: Can a fuel pump from a GTP work on a GT?
    SE Level Member keonmakesbeatz's Avatar
    Aug 2014
    Autoparts stores should rent out the gauge, can try to prime the pump 2 or 3 times before you try to start it and see if that makes any difference. If you said it sounds like it wants to start but isn't I'm thinking low fuel pressure because you were just recently messing with the pump. Giving it some gas not change anything?
    Sent from BFE
    I cycled the key a few times before I tried to start it . I waited until it had gas in the tank to cycle the key . But when I tried to start it, I found that the battery was dead and the battery had a "bad battery sticker on it when I picked it up from O'reilly's (i had it charged there) . After I had the battery charged, I cycled the key again, still nothing. The windows roll down and the radio turns on though . I haven't tried giving it gas . I was afraid it was gonna flood it . I don't really understand the flooding thing though
  2. #42 Re: Can a fuel pump from a GTP work on a GT?
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    It shouldn't flood it. I'd give it a try before pulling the pump again.
    Sent from BFE
    2012 F150 STX
    - Gonna be a race truck
  3. #43 Re: Can a fuel pump from a GTP work on a GT?
    Aug 2014
    Sent from BFE
    Okay . I'll try this first then switch the lines and do the same to see if it works . After I start it one time it should start up fine, correct ?
  4. #44 Re: Can a fuel pump from a GTP work on a GT?
    GTX Level Member 94grandprix's Avatar
    Jul 2010
    Crandall, Georgia, United States
    Hopefully, I don't think these cars can flood,let us know if you get it started
  5. #45 Re: Can a fuel pump from a GTP work on a GT?
    Aug 2014
    Quote Originally Posted by 94grandprix View Post
    What about starting fluid ? Should I try that ?
  6. #46 Re: Can a fuel pump from a GTP work on a GT?
    Jul 2010
    Was the car running when you bought it?,seems like if the pump is making a noise that it'd start,so no fuses were took out?
  7. #47 Re: Can a fuel pump from a GTP work on a GT?
    Jul 2010
    Not sure about starting fluid
  8. #48 Re: Can a fuel pump from a GTP work on a GT?
    Aug 2014
    He sold it to me because the fuel pump didn't work . None of the fuses were taken out by me . Could it be bad fuel lines ?
  9. #49 Re: Can a fuel pump from a GTP work on a GT?
    Jul 2010
    If you can't rent a tester like he was talking about,do you know where the nozzle thing is with a cap on it on the front of your fuel rail?
  10. #50 Re: Can a fuel pump from a GTP work on a GT?
    Aug 2014
    Yep . Depress it and see if it sprays, right ? Well it definitely sprayed with the other pump in but there was no gas in the tank
  11. #51 Re: Can a fuel pump from a GTP work on a GT?
    Jul 2010
    I doubt lines,have you looked under the hood and seen if the pump fusese were in there? Or maybe ICM if there is one,just glimps over and see if you see any missing and look over the ones in the glove compartment
  12. #52 Re: Can a fuel pump from a GTP work on a GT?
    Jul 2010
    Ok must have had some in the line,will it spray with this one?
  13. #53 Re: Can a fuel pump from a GTP work on a GT?
    Aug 2014
    Not sure yet my car is a couple miles away from me . I walk to it when I need to . The ICM is there and I haven't checked the fuses in the glove compartment .
  14. #54 Re: Can a fuel pump from a GTP work on a GT?
    Jul 2010
    I mean check if there is a ICM fuse,was the pump out of the car when you bought it?
  15. #55 Re: Can a fuel pump from a GTP work on a GT?
    Aug 2014
    Oh my bad . I dont know yet . I really haven't tried anything . And no it was not .
  16. #56 Re: Can a fuel pump from a GTP work on a GT?
    Jul 2010
    Ok,I guess try them few things,thats about all I know to do,I went through that,my pump made the noise but wouldn't start,had to fork out 240 for a new one,just let us know I'll try to think of what else it could be
  17. #57 Re: Can a fuel pump from a GTP work on a GT?
    Aug 2014
    I will update as soon as I test it. But holy crap $240 ?! It's one for $71 on rock auto .
  18. #58 Re: Can a fuel pump from a GTP work on a GT?
    Jul 2010
    I know now lol,but got a 5 year warranty, I'll swap it before it ends,got it at auto parts warehouse.com,don't never order from them
  19. #59 Re: Can a fuel pump from a GTP work on a GT?
    Jul 2010
    Just found a brand new one on eBay for 56
  20. #60 Re: Can a fuel pump from a GTP work on a GT?
    Aug 2014
    Oooh . That's a pretty good deal .
  1. Replies: 5
    Last Post: 06-22-2014, 07:32 AM
  2. will fuel pump out of a sc car work ib a na car
    By geep in forum General Grand Prix Discussion
    Last Post: 11-28-2013, 01:38 AM
  3. 97 GTP fuel pump woes: Rewire stock pump?
    By Powertrike in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-09-2013, 06:29 PM
  4. GTP Fuel pump.. Will a GT pump work?
    By azmattaz06 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-29-2012, 01:19 AM
  5. 2003 Limited Edition - Installing New Fuel Pump..How To Get The Pump Out?
    By corvettemike in forum General Tech Discussion
    Last Post: 04-07-2012, 10:04 AM
