Thread: Can a fuel pump from a GTP work on a GT?
Page 2 of 6 FirstFirst 1234 ... LastLast
Results 21 to 40 of 106
  1. #21 Re: Can a fuel pump from a GTP work on a GT?
    SE Level Member keonmakesbeatz's Avatar
    Aug 2014
    Yep . Pump hums, relay clicks . Haven't checked any fuses . It wouldnt even hum if there was a bad fuse in there right ?
  2. #22 Re: Can a fuel pump from a GTP work on a GT?
    GTX Level Member 94grandprix's Avatar
    Jul 2010
    Crandall, Georgia, United States
    I wouldn't think so,are the hoses or lines back right,I think they can't be crossed cause all 3 diffent
  3. #23 Re: Can a fuel pump from a GTP work on a GT?
    Aug 2014
    Quote Originally Posted by 94grandprix View Post
    Not sure . One hose looked slightly smaller so I put the smaller hose on the smaller little arm thing (idk what the technical term is), should I switch them ?
  4. #24 Re: Can a fuel pump from a GTP work on a GT?
    Aug 2014
    Is it possible that i've messed things up by crossing the lines ?
  5. #25 Re: Can a fuel pump from a GTP work on a GT?
    Jul 2010
    I looked at mine again its impossible to,was it the new style or did it plug right in?
  6. #26 Re: Can a fuel pump from a GTP work on a GT?
    Jul 2010
    The middle has the odd connector, is that one in the middle
  7. #27 Re: Can a fuel pump from a GTP work on a GT?
    Aug 2014
    It was the newer one I believe because it had a big lock ring . Not like the snap ring in mine . I took the actual pump out and put it in my assembly
  8. #28 Re: Can a fuel pump from a GTP work on a GT?
    Jul 2010
    I'm saying the power plugs,did they plug in?
  9. #29 Re: Can a fuel pump from a GTP work on a GT?
    Jul 2010
    When I bought mine new I had to cut one off and splice a new pig tail on
  10. #30 Re: Can a fuel pump from a GTP work on a GT?
    Aug 2014
    Yea the "new" pump had a different connector, I cut the wires and made it so I could plug it in with the old harness.
  11. #31 Re: Can a fuel pump from a GTP work on a GT?
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    Have you checked the fuel pressure?
    Sent from BFE
    2012 F150 STX
    - Gonna be a race truck
  12. #32 Re: Can a fuel pump from a GTP work on a GT?
    Jul 2010
    Ok swap the blacks and see
  13. #33 Re: Can a fuel pump from a GTP work on a GT?
    Aug 2014
    Sent from BFE
    I have not . I don't have a duel pressure gauge. Is there other ways to check pressure ?
  14. #34 Re: Can a fuel pump from a GTP work on a GT?
    Aug 2014
    I won't fack anything up will I ?
  15. #35 Re: Can a fuel pump from a GTP work on a GT?
    Jul 2010
    I did that with mine
  16. #36 Re: Can a fuel pump from a GTP work on a GT?
    Jul 2010
    Forgot to label so shouldn't hurt anything
  17. #37 Re: Can a fuel pump from a GTP work on a GT?
    Aug 2014
    Gotcha . Thank you for the help !
  18. #38 Re: Can a fuel pump from a GTP work on a GT?
    Jul 2010
    May or may not work but worth the try
  19. #39 Re: Can a fuel pump from a GTP work on a GT?
    Aug 2014
    Right
  20. #40 Re: Can a fuel pump from a GTP work on a GT?
    Apr 2012
    Dayton, OH
    Autoparts stores should rent out the gauge, can try to prime the pump 2 or 3 times before you try to start it and see if that makes any difference. If you said it sounds like it wants to start but isn't I'm thinking low fuel pressure because you were just recently messing with the pump. Giving it some gas not change anything?
    Sent from BFE
    2012 F150 STX
  1. Replies: 5
    Last Post: 06-22-2014, 07:32 AM
  2. will fuel pump out of a sc car work ib a na car
    By geep in forum General Grand Prix Discussion
    Last Post: 11-28-2013, 01:38 AM
  3. 97 GTP fuel pump woes: Rewire stock pump?
    By Powertrike in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-09-2013, 06:29 PM
  4. GTP Fuel pump.. Will a GT pump work?
    By azmattaz06 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-29-2012, 01:19 AM
  5. 2003 Limited Edition - Installing New Fuel Pump..How To Get The Pump Out?
    By corvettemike in forum General Tech Discussion
    Last Post: 04-07-2012, 10:04 AM
