Re: Hi....My name is Paul...and I own a Regal...can I come and play
What's this s3x hybrid Cam u speak of Paul?
It isn't done tuning yet, but I did track it with only 15* of advance on a cold track and ran 12.85 @111....my 60' is in need of some help. Dyno should be later this year
Dan-S3X with reduc lift so i can run the 1.8 rollers....actually almost as much lift as the S4X so i am kinda happy. I keep idle up about 800 so the lope isn't there.
Paul.. how does that profile differ from the S1X with 1.8's that I was running. Sounds like you are in the same range of lift (maybe a little more) plus different profile
Bill your lift on the stock s3X is .54 and .55...with mine I am .58 an .59...about the only difference....
Stock S1X is .51 and .52...so a little more lift....figured I had the 1.8's already might as well max it out.
sweeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeet. you should probably get to work on the mod list, its pretty skimpy...:th_boring: lol
Yeah...noting very limited and not nearly enough custom stuff....
