Thread: HELP!! Possible Turn Switch Failure???
Results 1 to 7 of 7
  1. #1 HELP!! Possible Turn Switch Failure???
    Enfield, CT
    Just earlier this week my passenger side HID would flicker but not stay on when I turned the switch to light’em up. I figured it was a ballast and decided to put the stock bulbs back in tonight. Well the passenger side stock bulb lights up and so does the high beam bulb at the same time??? I don’t even have the switch set to high beams. At the same time, the driver side low beam is bright but the high beam is very dim. When I push the switch to high beams, only the passenger side goes out completely. Also I have no Cruise Control and got a P0564 code (Cruise Control Switch Circuit Malfunction) once a couple weeks ago. Haven’t been able to replicate code.
    There’s way too much to even bother typing. Here’s pics and a video. Click on the first one to see the video
  2. #2 Re: HELP!! Possible Turn Switch Failure???
    Enfield, CT
    no help lol?
  3. #3 Re: HELP!! Possible Turn Switch Failure???
    Enfield, CT
    well I'm gonna buy a new one and hope it fixes it
  4. #4 Re: HELP!! Possible Turn Switch Failure???
    That's the spirit!
    If you are installing at work after hours.. LMK, I'd like to see how ugly of a job it is.
  5. #5 Re: HELP!! Possible Turn Switch Failure???
    I had a light issue like that and it was a bad ground, behind the headlight but didn't have the cruise control nor parking light issue you're experiencing.
  6. #6 Re: HELP!! Possible Turn Switch Failure???
    Enfield, CT
    Problem fixed. Bad ground near the headlight. I completely missed that ground before. I replaced the CC switch and the CC is back!
    Sorry Bill, I got transferred to Boston RD. This is the instructions I followed, http://www.instructables.com/id/How-...n-04-Pontiac-/
    Putting the cover back on is a *****!
  7. #7 Re: HELP!! Possible Turn Switch Failure???
    Now you are up on BR. That sucks distance wise for me. LOL. Probably a nice bit closer to home for you.
  1. turn signal switch ???
    By bubba40 in forum General Tech Discussion
    Last Post: 07-23-2010, 12:30 PM
  2. Turn signal switch... bad?
    By 1988 Grand Prix in forum General Tech Discussion
    Last Post: 09-23-2009, 08:20 PM
  3. Turn signal switch... bad?
    Last Post: 09-18-2009, 11:17 PM
  4. turn signal switch
    By vailskier3 in forum Audio, Security & Visual Electronics
    Last Post: 07-15-2009, 08:10 PM
